Slingsby Gull scale 1/4
1, 2, 3, 4, 5, 6 Suivante
Âge: 79 Vierge
MessagePosté le: 15/04/2020 13:20    Sujet du message: Répondre en citant
Danke Olli, ja Ich war ganz gut gelaunt wenn die Querruder gut functionierten Very Happy Very Happy
I go on in English, the Gull is completed on the outside,the sun was shining, so I took the Gull outside for some pictures
Adri made the name and the numbers on the wing, registration letters were not needed at that time
You can see at my face (straight in the sun) that the Gull is quite heavy Sad
Some detailing of the cockpit is still to be done.
Vincent (DB)
Franco Vallari
MessagePosté le: 15/04/2020 14:20    Sujet du message: Répondre en citant
[clap] Formidable!!!! [clap]
Âge: 60 Taureau
MessagePosté le: 15/04/2020 14:28    Sujet du message: Répondre en citant
Waouh, superbe [amen] [amen] [amen] ! Très belle finition [clap] [clap] !
Il ne reste plus qu'à prendre l'air !
MessagePosté le: 15/04/2020 16:08    Sujet du message: Répondre en citant
Marvelous ! [clap]
you are a strong men ! position of victory Wink
keep cool, some weeks again…
Âge: 79 Vierge
MessagePosté le: 15/04/2020 16:19    Sujet du message: Répondre en citant
Thanks Franco Sed and Sebastian, yes it was quite heavy and my wife didn't know my camera, it took some time MDR
I am afraid it will take some time before we are allowed to fly again, but I'll keep you informed.
Vincent (DB)
Âge: 54 Gémeau
MessagePosté le: 15/04/2020 20:46    Sujet du message: Répondre en citant
Bravo Vincent, it's magnificent ! [amen] [amen] [amen]
I knew we would have finished our gliders at the same time Cool Wink
Ready to go to the slope or field. We just Don't know exactly when it's possible... [humm]
Friendly Very Happy
Âge: 79 Vierge
MessagePosté le: 15/04/2020 23:10    Sujet du message: Répondre en citant
Thanks Lolo for your comment! Very Happy Very Happy Very Happy
Yes we have to wait, I am going to finish the interior [scie]
Vincent (DB)
Greg
Âge: 84 Taureau
MessagePosté le: 16/04/2020 19:26    Sujet du message: Répondre en citant
[clap] [clap] Il est superbe, en vol ce sera un régal ...
Bon, on attend [argh]
Le vent se lève .....
MessagePosté le: 16/04/2020 20:00    Sujet du message: Répondre en citant
Herzlichen Glückwunsch zu diesem tollen Modell [amen]
und danke für den interessanten Baubericht, Vincent [good]
Jetzt wollen wir nur noch hoffen das sich die Situation um das Coronavirus
sich bald bessert und du das schöne Modell bald einfliegen kannst Very Happy
Liebe Grüße und bleib gesund
Âge: 79 Vierge
MessagePosté le: 17/04/2020 19:01    Sujet du message: Répondre en citant
Merci Greg und danke Johannes fur das commentar Very Happy Very Happy
Muss nur noch an dem Cockpit und Piloten arbeiten und dann warten ob besseren Zeiten fur die Erstflug....
LG und ja, bleibt gesund,
Vincent (DB)
MessagePosté le: 17/04/2020 19:23    Sujet du message: Répondre en citant
Magnifique ! [clap] [clap] [clap]
Encore un chef d'oeuvre [bave]
Âge: 79 Vierge
MessagePosté le: 17/04/2020 19:46    Sujet du message: Répondre en citant
Merci Eric, I am feeling humble from all those nice comments Very Happy Very Happy
It still didn't have its maiden flight, hopefully that will be less nervewrecking as with the Fokker FG-2.
Friendly,
Vincent (DB)
Âge: 77 Bélier
MessagePosté le: 20/04/2020 11:10    Sujet du message: Répondre en citant
Hallo Vincent,
einfach klasse, das Modell. [clap] [amen] Und wie schwer ist es geworden? [humm]
Gruß Manfred
Âge: 79 Vierge
MessagePosté le: 20/04/2020 11:28    Sujet du message: Répondre en citant
Danke Manfred Very Happy.
Leider ist sie schwerer geworden wie gepland. 5200gr im Gull I ausfuhrung (2X 10mm kohlefaser Flugelverbinder und Flugelstutszen?) oder 5600gr wie Gull II I met 2X 10mm stahl Flugelverbinder (ohne Flugelstutzen?). Bei ein Flugelflache von 95 dm2 gibt es ein belastung von 56 oder 59 gr/dm2. Vielleicht auch nicht slecht, weil wir nahe die kuste fliegen und immer viel wind haben.
LG,
Vincent (DB)
Âge: 63 Capricorne
MessagePosté le: 20/04/2020 15:00    Sujet du message: Répondre en citant
Ma-gni-fi-que !
Quel beau travail et c'est un très beau planeur que j'aime beaucoup . Bravo !
Âge: 79 Vierge
MessagePosté le: 25/04/2020 10:23    Sujet du message: Répondre en citant
Merci Philippe et oui j'aime cette planeur aussi Very Happy.
Je travaille maintenant a l'interieur, mais il n'y a pas beaucoup d'information, helas.
Vincent (DB)
Âge: 79 Vierge
MessagePosté le: 29/04/2020 16:03    Sujet du message: Répondre en citant
Bonjour a tous,
Some time ago I had already made the head, ( see page 7), helped by a nice tutorial https://www.youtube.com/watch?v=WlPYWe2bGUo
from super sculpey. Its is made round a clump of aluminium foil on a wooden peg, which I later removed. I started painting it with acrylics, shortly after that my wife took it over ( I was quite pleased).
This close it looks a bit exagerated, but I think a model needs that to look realistic. In the meantime I made a pair of sunglasses from hard brass wire, with glasses of an old polaroid one. I also made hands from super sculpey, reinforced with a copper wire (mains electric wire)
The copper wire slides in a hole in the arm and glued with PVA
My sister Hans had finished the clothing, it fitted nicely, even his trousers were ironed Very Happy
His head is fixed on a wooden dowel, glued with PU in his hollow head
The peg is secured with some velcro in his body, just to get some friction.
The pilot needed a harnass, which I could not buy at the time, so I made one of elastic band, stitched on some leather (again an old wallet) and I used brass bushes which go at servo's. It was toned down with an airbrush. The safety pin was bend and soldered from hard brass wire and some brass strip.
Handle for the spoilers
closure lock of the canopy
release handle for the dolly
leather pouches
hinges for the rudder pedals, made from plasticard, with pins as bolts
en all put together
the middle steel wire with the red ball is the uncoupler. The pilots fits in
and with a closed canopy
With the interior and pilot finished the Gull is now ready to fly, I just have to wait till its possible, just wait and see...
Vincent (DB)
MessagePosté le: 29/04/2020 17:43    Sujet du message: Répondre en citant
Bravo Vincent, magnifiques tous ces détails [clap] et le modelage de ton pilote est très réussi [clap]
Âge: 79 Vierge
MessagePosté le: 29/04/2020 18:10    Sujet du message: Répondre en citant
Merci pour les comments Vincent Very Happy et Jenny fait la peinture de la pilote Very Happy
Vincent (DB)
Claude Moinier
Âge: 75 Verseau
MessagePosté le: 29/04/2020 20:31    Sujet du message: Répondre en citant
Prachtig Vincent [clap] [clap]
I Fly without Engine
ClaudeM
Âge: 79 Vierge
MessagePosté le: 29/04/2020 22:14    Sujet du message: Répondre en citant
Dankje Claude, Very Happy en nu nog vliegen!
Groet, Vincent (DB)
MessagePosté le: 29/04/2020 22:25    Sujet du message: Répondre en citant
Hi Vincent,
dein sehr schön gebautes Flugzeug wird duch die tolle Einrichtung
und den schönen Pilot unm noch einiges aufgepeppt - super [amen] [amen]
Gruß mit der Hoffnung das der Erstflug nicht
zu lange auf sich warten muss
Âge: 80 Verseau
MessagePosté le: 30/04/2020 08:49    Sujet du message: Répondre en citant
Proficiat. Prachtig. En nu nog vliegen.
Mvg.
Harold
Âge: 79 Vierge
MessagePosté le: 30/04/2020 09:09    Sujet du message: Répondre en citant
Danke Johannes en Harold Very Happy Very Happy
Geduld fur die erstflug....
LG, met vriendelijke groet,
Vincent (DB)
Âge: 63 Capricorne
MessagePosté le: 30/04/2020 16:56    Sujet du message: Répondre en citant
Superbe Vincent, j'adore ton pilote. C'est du beau travail !
Âge: 79 Vierge
MessagePosté le: 30/04/2020 21:43    Sujet du message: Répondre en citant
Merci Philippe pour le pilote Very Happy .
Le "tutorial" https://www.youtube.com/watch?v=WlPYWe2bGUo est tres bonne avec des instruction tres claire, malheureusement c'est en Anglais.
Vincent (DB)
Âge: 60 Poissons
MessagePosté le: 01/05/2020 09:13    Sujet du message: Répondre en citant
Bonjour Vincent
Bravo l'intérieur est magnifique [baaave] [amen]
tu es un vrai sculpteur, le pilote est super [good2]
je te souhaite bon vol
Michel [vol]
Âge: 79 Vierge
MessagePosté le: 01/05/2020 15:02    Sujet du message: Répondre en citant
Bonjour Michel,
Merci pour ton comments Very Happy Very Happy . Heureusement il y a du progress dans les pilotes!
On attend l'ouverture de site pour voler...
Vincent (DB)
Âge: 77 Bélier
MessagePosté le: 03/05/2020 12:19    Sujet du message: Répondre en citant
Hier stimmt einfach alles - [amen] Modell, Cockpit und das fliegende Personal. [clap] Very Happy Wunderbar [clap]
Dann auf zum Erstflug
Gruß Manfred
Âge: 79 Vierge
MessagePosté le: 03/05/2020 23:24    Sujet du message: Répondre en citant
Hello Manfred,
Danke Very Happy Very Happy Very Happy , und dann die Erstflug, soll leider noch ein bisschen dauern!
Gruss,
Vincent (DB)
Page 5 sur 6
