gianfry2866 Stagiaire Posteur
Posté le: 12/07/2007 16:55 Sujet du message: |
how to have this plans in italy???? |
Posté le: 12/07/2007 17:40 Sujet du message: |
Good evening first ! Here it's like a family place thank you... |
Posté le: 12/07/2007 17:48 Sujet du message: |
Hi Gianfry
Contact LoopingFred! He sell plan or short kit of his KA3!
Enjoy
Erwan |
Posté le: 12/07/2007 18:14 Sujet du message: |
tks at everyones
i'll tried to contact via e-mail and mp several times...
but no answer i recived.......
i will try again ...tks |
Stephan Psycho Posteur
Posté le: 12/07/2007 18:36 Sujet du message: |
tks a lot stephan.... |
Posté le: 12/07/2007 20:55 Sujet du message: |
MANY TKS..... |
loopingfred Incurable Posteur
Posté le: 12/07/2007 21:36 Sujet du message: |
after 48hrs of travel, I'm back home ! Need to rest now !
Gianfry, I have all your mails and PM, i'll answer all of them asap.
MORE BEERS!!!! |
Posté le: 03/07/2008 17:02 Sujet du message: |
after one year and my first son...i decided to start build the ka3.....
now the first problem.....
on the short kit by Fred all the ribs are precutted for a longherons pin of 17x7......but it's impossible to find at any brico this kind of mesure...
someone may suggest how to solve this problem....i don't wont cut new ribs for a different longherons....
the only mesure i have found is oyus 15x5..........
tks a lot |
Posté le: 03/07/2008 17:21 Sujet du message: |
Hi Gianfry,
Glad you finaly going to start the Ka3 !
For the 17x7, I don't really have a solution...
Maybe glue a 2mm balsa strip on 2 sides on the 15x5 pine you have found
I did that once for one of my glider, and worked fine...
Other than that, you will have to cut your own spar
Another thing while we are at it, because you have an old kit, can you measure the lenght of the ribs compared to the plan ?
If you find any differences, can you send me your address by PM ? and I'll will send you a new set of ribs (but still with a 17x7mm spar I'm affraid...). I don't recall I have contacted you regarding this issue
Fred
MORE BEERS!!!! |
Posté le: 03/07/2008 18:18 Sujet du message: |
ok fred i will compare the ribs with the plans ....ana i will let u know |
