Daniel Stagiaire Posteur
Posté le: 05/11/2007 15:32 Sujet du message: |
Muy bonitos.... |
TorresM Apprenti Posteur
Posté le: 06/11/2007 10:16 Sujet du message: Hola Daniel |
Bienvenido al foro. Estoy a tu disposición, si en álgo te puedo servir...
Bons Vols...
Manolo |
Stephan Psycho Posteur
Posté le: 06/11/2007 10:22 Sujet du message: |
Hi guys
nobody than you can follow this discussion in the forum. It would be nice if you could change to a language which at least the majority of the members could understand (german for example )
Stephan |
Posté le: 06/11/2007 10:50 Sujet du message: |
Hi Stephan,
Yes I agree with you. If you read my yesterday's post I asked not to speak Spanish here (even if I whish) or a different languaje than French/English, because I think that evertybody must understand what it is being discussed....
We can always send PM.
Thanks a lot Manolo !!
Daniel |
Posté le: 06/11/2007 19:46 Sujet du message: |
Here you have my today's progress.... do not think I'm going to take pictures of every single piece of wood cutted, it is just because it seems that we are loosing the thread of this post
As I advise you at the beginning, it is going to be a very slooooow building, because.
1.I do not have a CNC machine, so I have to cut all the pieces by hand.
2.Not too much time to build.
3.Two kids at home.
But do not worry I think I'll be maiden it on Retroplane 2015 |
Posté le: 06/11/2007 19:54 Sujet du message: |
Daniel
Don't worry, it is not a race Everybody makes on his speed, time after time with pleasure of course
I find you go ahead with a good rate even you do all thinks with your hands! So, so
Posté le: 06/11/2007 20:00 Sujet du message: perdon |
Bien. Je seul donnais la bienvenue au forum à un nouveau membre.
Stephan, j'entends ton problème. Il est le même que j'ai devant les écrits chez l'Allemand.
Perdon, S.V.P.
Bons Vols...
Manolo |
Posté le: 07/11/2007 10:08 Sujet du message: |
Bon Jour
I'm planning to finish cutting all the formers of the rear part of the fuselage (if I'm lucky), as well as the quille.
But I have one question:
On the formers there is a part on bottom that must be removed (is for allignment) after the fuselage is finished (and before covering it), and I think it must be pre cutted in some way because if not, it will be difficult after all is glued. See attached sketch
Am I right? Or do you have any other suggestion?
Thanks in advance
Daniel
PS Stephan/Manolo, let's calm down....we all have good willing but sometimes is unavoidable to turn to your own languaje |
Posté le: 07/11/2007 11:19 Sujet du message: |
« Daniel » a écrit: ...On the formers there is a part on bottom that must be removed (is for allignment)...
exactly as you said, it's for allignement and has to be removed
it is better to cover what ever is possible to cover before cutting them, thus you can avoid any distortion
« Daniel » a écrit: ...and I think it must be pre cutted in some way because if not, it will be difficult after all is glued.
...yes, the formers from Vincent have a slight pre cut, thus no problem for the final cut
Stephan |
Posté le: 07/11/2007 11:32 Sujet du message: |
Danke Stephan |
