czirh Accro Posteur
Posté le: 11/05/2009 13:59 Sujet du message: |
Hello ...
Unfortunately, despite all my efforts, I was not able to get an Irish visa.
I want to thank Vincent and Fred for all their kind assistance and support ...
P.S. Kindly remove me from the list ...
Cem Zırh
Fafnir |
Posté le: 11/05/2009 14:21 Sujet du message: |
Hi Cem, hooo shit and I see on Pistbasi forum you made a nice box in plywood
Posté le: 11/05/2009 16:53 Sujet du message: |
Very sorry, i hope you can come for the next retroplane.
Erwan |
loopingfred Incurable Posteur
Posté le: 12/05/2009 11:46 Sujet du message: |
Cem, what was the issue with the Visa ?
If you need anything, like an address or else...
Have you contacted the Turkish Embassy in Dublin ? (Tel: (00.353)16 68 52 40) There is certainly a way
MORE BEERS!!!! |
czirh Accro Posteur
Posté le: 13/05/2009 10:10 Sujet du message: |
Just a band of wasters !
And they are complaining that tourism is getting low in the country, no wonder why !!
I think that's mad to ask for all that from the start !
Anyway, that is Shengen, so if I'm correct, if you had a visa for another EU country, application for another EU country should be done without any issues of questions
Let me ask and complain to the dpt of foreign affairs... We'll see the answer!
MORE BEERS!!!! |
czirh Accro Posteur
Posté le: 13/05/2009 10:24 Sujet du message: |
Thank you Fred, very kind of you ... I also wanted to write to the embassy myself but changed my mind and took me quite an effort to tranquilise my wife not to make it a scandal
Unfortunately, Ireland is not Schengen. I have some real good visas and they would have helped plenty (i.e. I have one year Greek Schengen with multiple entry ... Can you imagine?).
Take care & be happy
Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 13/05/2009 10:34 Sujet du message: |
Well, that was quick !
I don't know how you've applied to the Visa, but the Dpt of Foreign affairs said that you can use the new AVATS online system (?). System is new, and available in the Irish Embassy in Ankara.
Ugur Mumcu Caddesi No.88
MNG Binasi
B Blok Kat 3
Gaziosmanpasa
Ankara 06700
312-446 6172
It's an online application system. You still need the 6 months bank details, but might not be needed to be translated and that's it (to make sure you can be in Ireland without help from anybody .
And I found this : http://www.dfa.ie/home/index.aspx?id=74993
You can apply online here...
Hope this help, fingers crossed anyway!
MORE BEERS!!!! |
Posté le: 13/05/2009 10:36 Sujet du message: |
God yes, you are right ! Ireland is not Schengen !!
Even more a bunch of complete wasters !
MORE BEERS!!!! |
czirh Accro Posteur
Posté le: 13/05/2009 11:00 Sujet du message: |
« loopingfred » a écrit: Well, that was quick !
I had to go to Istanbul due to my residential location. And had to travel 12 hrs each way! So, prior my travel I made sure I had everything right to avoid any inconvenience and that includes several phone calls to the embassy and yes, I used the online application.
Fred, you are a good guy, thanks for all! Hope to meet you some day
Cem
Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 14/05/2009 22:09 Sujet du message: |
I plan to fly My Doppi with towplane :
a) What should be the power of the towplane to tow a Doppi size sailplane?
b) What kind of towline should I use? What should be the diameter; length and material (metal or nylon fishing line)?
I would be thankful for any additional suggestions!
Cem Zırh
Fafnir |
Stephan Psycho Posteur
Posté le: 14/05/2009 22:51 Sujet du message: |
« czirh » a écrit: I plan to fly My Doppi with towplane :
Cem
In general you take a cord of 25m long and 3mm diameter. You can find such cords in a building center. At both ends you fix a kind of a ring with smaler diameter, 1mm, a kind of fishig line, or you buy this one from the champion
http://www.f-schleppontour.de/html/schleppseile.html
With regard to power, for the Dopp not much is needed because its only about 3kg, a Big Lift with a 20ccm engine would easily do the job.
Cheers
Stephan |
Posté le: 15/05/2009 05:37 Sujet du message: |
Hi Cem, I towed my Dopp with a trainer and old 15cc, it was enought. I don't try but I think a good 10cc with a good tug's pilot should be enought, but more 20, 35, 50cc.... is always better for security, but the pilot should make slowly with throttle's stick
Posté le: 15/05/2009 06:33 Sujet du message: |
Hello
For the secure ring , in my club , we use nylon string used for fishing, we take 30 kg (= 60 pounds) string
For the tractor, 20 cm3 glow or 30 cm3 petrol are very good for start this exercice
Erwan |
czirh Accro Posteur
Posté le: 15/05/2009 11:35 Sujet du message: |
THANK YOU :
Very helpful !
Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 16/05/2009 11:35 Sujet du message: |
Good morning ... A happy week-end to you all!
Again me with my boring questions My apologies but looked every where and cannot find answers! And I have no sources here
Position of the release hook on the towplane wing?
Is there a link to see a picture of the system?
How many cm behind should it be from the CG?
As the towplane, we plan to use Senior Telemaster, 25 cc gasoline engine ...
Senior Telemaster:
http://www.model-fan.com.pl/index.php?p2721,senior-telemaster-60-arf-airline
I have a 46size Super Decathlon (by Phoenix) with ASP 61 4c engine. Is it possible to use this plane as a towplane if we put a stronger engine?
Super Decathlon:
http://rcmodelairplane.tr.gg/Super-Decathlon.htm
Thank you in advance ...
Cem Zırh
Fafnir
czirh Accro Posteur
Posté le: 16/05/2009 16:27 Sujet du message: |
Merci beaucoup Vincent ...
Very useful ... I will let you know.
Have a wonderful week-end!
Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 27/05/2009 09:58 Sujet du message: |
My Doppi in Ankara 2m RES regatta..
Cem Zırh
Fafnir |
Posté le: 27/05/2009 10:12 Sujet du message: |
Hi Cem,
Doppy flew? you had towed it?
czirh Accro Posteur
czirh Accro Posteur
Posté le: 01/07/2009 23:16 Sujet du message: |
nice video Cem
pat'
Posté le: 01/07/2009 23:54 Sujet du message: |
I agree nice video. Listen Cem, I read in the intro the name Philip Kolb. Is he in your club?
Cheers
Stephan |
Benoit1664 Accro Posteur
Posté le: 02/07/2009 07:17 Sujet du message: |
excellent vidéo........
( dixit ma Môman...) |
czirh Accro Posteur
czirh Accro Posteur
Posté le: 02/07/2009 10:23 Sujet du message: |
« patte de loup » a écrit: nice video Cem
pat'
« Benoit1664 » a écrit: excellent vidéo........
Merci beaucoup
You may also like watching this by another friend : http://vimeo.com/5412964
Cem Zırh
Fafnir |
plu ronan Incurable Posteur
Posté le: 02/07/2009 10:46 Sujet du message: |
very good video |
