Posté le: 24/01/2010 08:47 Sujet du message: |
Many thank Roberto from my friend Gérald, enlarged your files, span 3.60m and he started the building
klajmen Stagiaire Posteur
Posté le: 24/01/2010 09:21 Sujet du message: |
New Mucha 100 France ???!!! SUPER France flew the original one Mucha 100. Unfortunately, I do not have the pictures and I do not know its history. Vincent, if you need pictures or paint scheme write.
Roberto if you can get the plans from your model?
RobertoP Fidèle Posteur
Posté le: 24/01/2010 13:32 Sujet du message: |
Hi Vincent,
I am very happy that your friend Gérald has appreciated my project ,for me is a beautiful thing to share my drawings with other enthusiastic of vintage glider.
Many congratulation to Gérald for the very good construction , the 3.6m is a very good size.
For Klajmen, if you send me your e-mail I can send you the CAD fail of my project.
Regards
Roberto
Posté le: 19/04/2010 19:05 Sujet du message: |
Les dernières photos du Mucha de Gérald, il ne lui reste plus que la finition à faire
plu ronan Incurable Posteur
Posté le: 19/04/2010 19:10 Sujet du message: |
beau boulot
et un atelier mieux rangé que le mien
Jean-Paul Incurable Posteur
Posté le: 19/04/2010 20:16 Sujet du message: |
Oui, beau travail et l'atelier n'est pas mal non plus, et chauffé en plus !!
Posté le: 19/04/2010 21:49 Sujet du message: |
i Vincent
again many compliment to Gerald for the construction. I need to apologize with you and Gerald but I have checked the CG indication on my drawing and I need to underline that the position indicated is wrong,
you need to move forward the position of CG of about 5mm. Obviously considering that you have scaled my drawings you need to recalculate the position. Moving the CG 5mm forward the CG is placed at 39% of medium chord.
Regards
Roberto
cassin jean Fidèle Posteur
Posté le: 16/11/2010 12:21 Sujet du message: |
Et non , avec IE , même en faisant "enregistrer la cible sous .." ça ne veut pas marcher . J'obtiens un grand carré blanc avec une petite croix rouge en haut à droite ...
Salut Vincent .
Posté le: 16/11/2010 12:24 Sujet du message: |
Si tu fais enregistrer la cible sous... ça t'enregistre le fichier là où tu veux, bureau, mes docs... donc après t'ouvres ce fichier avec la visionneuse windows ou autre soft, sauf IE
Posté le: 16/11/2010 12:30 Sujet du message: |
Ok merci , je vais essayer !
Salut .
