uav-oscar Apprenti Posteur
Posté le: 03/03/2011 16:10 Sujet du message: |
Thank you Vincent..
As I remember almost 17-18 years ago I built these kind of construction.. For a looong years I fly ARF models (planes etc.)
It is good the see that I still remember how tho make scratch build models.. |
Posté le: 03/03/2011 16:12 Sujet du message: |
During Doppi construction , I stop all other projects..
Posté le: 03/03/2011 16:14 Sujet du message: |
Fusalage without elevator & rudder now 353 grams.. Not soo bad I guess..
Posté le: 03/03/2011 16:17 Sujet du message: |
What is this glider blue and white?
For the weight, don't worry, there are Doppi from 2.5 to 3.5kg we don't see difference in flight
Last weekend I visit one of my friend who built static models..
He paint gauge panel with airbrush mat black colour ..
Posté le: 03/03/2011 16:19 Sujet du message: |
Some scale details..
Posté le: 03/03/2011 16:21 Sujet du message: |
« VincentB » a écrit: What is this glider blue and white?
Vincent,
that one ORLIK II , I bought from one of friend in last retroplane meeting in Bursa Turkey..
After that I decide to build Doppi.. |
Posté le: 03/03/2011 16:36 Sujet du message: |
Nice work, congratulations |
czirh Accro Posteur
Posté le: 03/03/2011 18:03 Sujet du message: |
İyi akşamlar, Özgür.
Doppi çok güzel ve iyi uçan bir model...
Seçimin ve inşaatın için kutlarım.
Cem Zırh
Fafnir |
Posté le: 03/03/2011 19:21 Sujet du message: |
Rudder construction..
Posté le: 03/03/2011 19:23 Sujet du message: |
Rudder & elevator meet with fusalage just for picture..
Posté le: 03/03/2011 19:43 Sujet du message: |
Ok , time to start wing
Main spar 10x5 mm spruce can be found here only 1 m. long , for that reason I need to make extension
45 degree cut is best angle for max. strength..
I use 30 min. epoxy for this part..
osevgi Apprenti Posteur
Posté le: 03/03/2011 20:46 Sujet du message: |
Yeni forum hayırlı olsun Özgür |
Posté le: 03/03/2011 20:48 Sujet du message: |
Tesekkurler abi.. |
Posté le: 04/03/2011 05:24 Sujet du message: |
This is the first Doppi in Turkey which build from Cem Zirh and mine will be the second one..
Posté le: 04/03/2011 10:04 Sujet du message: |
Posté le: 04/03/2011 22:45 Sujet du message: |
Thanks Christian... |
Posté le: 04/03/2011 23:01 Sujet du message: |
Tomorrow I will start building the wings..
But tonight I have a problem... I do not know if its dxf mistake or my laser cut machine problem???
Main spar shown 5x10mm on the plan & dxf, but all ribs (balsa & plywoods) have 6x10mm cut for spar..
As a solution I cut tiny pieces from 1mm balsa and glue it every ribs on the wing..
Posté le: 04/03/2011 23:04 Sujet du message: |
I fix this problem but it took long time.. I am ready for wing construction now..
Posté le: 05/03/2011 05:51 Sujet du message: |
I re-checked the dxf is well 10x5mm
Strange indeed that the cuts are at 11mm
There is not a bad parameter cutting, which cuts outside the lines?
Posté le: 05/03/2011 16:42 Sujet du message: |
Some details on wing construction..
I use carbon tubes for wing joiner..
Dihedral...
Posté le: 05/03/2011 16:43 Sujet du message: |
Posté le: 05/03/2011 16:47 Sujet du message: |
My friend Osman abi help me a lot for the wing construcion.. Honestly as I did not build scratch style for long years, I request him to help me..
He is a more then 40 years modeling experience ( especially Free Flight), also he is building http://www.retroplane.net/forum/viewtopic.php?t=3310
Zlin Z-24 ..
Thank you Osman abi.. |
Posté le: 05/03/2011 16:50 Sujet du message: |
Posté le: 05/03/2011 16:52 Sujet du message: |
Now I am waiting for drying time of Aliphatic glue..
Posté le: 05/03/2011 19:02 Sujet du message: |
It's nice to work with friends Good job |
