Posté le: 09/11/2014 23:31 Sujet du message: |
Very nice work and beautiful model. I like very much that such of antic models.
So good this idea for the nose. It looks very nice.
OliverPrinz Apprenti Posteur
Posté le: 13/12/2014 17:19 Sujet du message: opening |
Salut à tous,
Sorry for this delay in reporting. The next couple of weeks will be better.
The constructor has designed the nose to be removable for entering the fuselage. There could be some magnets holding the entire nose. But for me (and my fingers) this is not big enough. I decided to make an opening from the top (as usual).
First I had to double some parts of formers to be able to cut the strings for the opening.
Comment for those who want to do the same:
It would have been better to water all the strings, because if glued in without them being watered, they hold a lot of tension. As soon as you use your saw, they "jump back" into a straighter position which makes it difficult to keep them in a bend position.
I had to glue in a lot of additional braces to keep the strings in round shape
Using a rest of fiber and a bit of Paulownia wood I've created a "look for this opening.
At the end, there's a bigger opening to make it possible to see and manipulate everything in the fuselage.
Hope you like it
Orionis Incurable Posteur
Posté le: 15/12/2014 18:49 Sujet du message: a bit of RC |
Unfortunately there is nearly 100g of weight needed in the nose to set up the right point of gravity
This way the glider weighs (still without varnish) nearly 700g.
Here are some impressions of "my remote"
One of my favorites are pipes for the receiver antennas to keep them in a 90° angle and (of course) for protection and easy removability
Now it's time for the gas mask and lots of dope... |
Posté le: 15/12/2014 19:10 Sujet du message: |
Magnifique
Posté le: 15/12/2014 20:01 Sujet du message: |
Salut Oliver !
Chapeau bas !
stéphane monot Accro Posteur
Posté le: 15/12/2014 20:08 Sujet du message: |
C'est très beau cette dentelle.
Stéphane |
Posté le: 24/12/2014 17:42 Sujet du message: mistakes needs to be done |
Ok, I knew it before but did not take care of:
the varnish/dope (Spannlack) is so strong, it's bending the last spare of the rudder ...
No chance to leave it like it is:
It needs more struts to enforce:
At least this correction is "invisible" and the spare is straight again
Posté le: 04/01/2015 23:31 Sujet du message: it's done |
Today I've finalized the Jaguár with 705g lift-off weight
Here some more details:
Now I'm waiting for a good chance for the very first flight (with my knees shaking ) |
Posté le: 05/01/2015 00:16 Sujet du message: |
So nice, I love it !
Gool luck for the maiden flight and Happy new year.
Erix Fidèle Posteur
Posté le: 05/01/2015 08:41 Sujet du message: |
Hi Oliver,
Nice "homework". Good luck for first fly. Double jigger makes automatic 20% exponential for flight
Greetings Erix |
Posté le: 05/01/2015 09:12 Sujet du message: |
Lovely built model Oliver , quite light, a feather ! |
Posté le: 05/01/2015 12:14 Sujet du message: |
Salut Oliver !
Superbe planeur !
J'espère pour toi que le vol sera à la hauteur de ta construction !
Posté le: 05/01/2015 19:15 Sujet du message: |
belle construction.
Posté le: 05/01/2015 20:35 Sujet du message: |
Good luck for the maiden flight, don't forget your photographer!
Fabrice |
de plancke Incurable Posteur
Posté le: 05/01/2015 22:21 Sujet du message: |
Toujours aussi beau ces antiques
Tom
Miguel Gil Apprenti Posteur
Posté le: 06/01/2015 01:40 Sujet du message: |
Very nice construction. Happy flights.
Miguel. |
Posté le: 07/01/2015 18:29 Sujet du message: |
Thanks a lot for your replies and greetings.
I promise to upload a video too
Oliver. |
Posté le: 05/03/2015 19:56 Sujet du message: glider in the box |
Meanwhile I've made a box for easy and safe transportation.
Have a look...
https://www.youtube.com/watch?feature=player_embedded&v=V45YYvdWtNs
First the needed space for the Jaguár theoratically:
Some more wood ... and later on "a box":
My wonderful wife Karin painted the box to be not that "white".
Meanwhile the interior found its final situation more an more:
This should be mentioned ...
the gilder can be setup up in the box safely without having the wind "grapping".
Afterward you just take it out and fly
I will come back with the maiden flight.
So long,
Oliver. |
Posté le: 26/04/2015 07:32 Sujet du message: maiden flight |
This wonderful plane took off in the air just great. First by throwing out of the hand, later on with high start.
Nothing irregular happend, just an easy ride with the wind
https://www.youtube.com/watch?v=0W713f0D2Fs
Oliver. |
Posté le: 26/04/2015 10:17 Sujet du message: |
Very nice flight, I'm in love with that sort of model. Wonderfull work !
Congratulations.
Posté le: 26/04/2015 21:45 Sujet du message: |
Nice flight, very good result for a neat construction. It shows good stability and it's rather speedy |
Posté le: 27/04/2015 19:58 Sujet du message: |
Paul_BB Fidèle Posteur
Posté le: 21/05/2015 06:45 Sujet du message: |
Beautiful. Congratulations. |
