Posté le: 20/09/2016 14:12 Sujet du message: |
Les tubes de chez tubos capillares sont très raides, et le stab est situé très haut, donc vraiment peu de chance de l'abimer, pour moi c'est inutile d'ajouter du carbone, mais bon tu fais comme tu veux....
bocorvin Maniaco Posteur
Posté le: 28/09/2016 17:09 Sujet du message: |
Hello everyone,
Thank you Vincent for convincing me, that the thin walled tube (0.25 mm) is strong enough!
I received the new tubes and made a new tailboom. It looks identical as the old one , but it weighes only 160 gr
Next the horizontal stabilizer; I looked at pictures from the "alte news"
http://www.collectors-edition.de/Alte%20News/english.htm in which is described how they build a exact replica's of Fokker fighters of WW1.
 I also used a partly enhanced picture from Hans Disma collection
 which showed a lot of info.
I made a jig from 4mm plywood for the horizontal and vertical stabilizers. I used 5 mm tube for the main spar and 3mm tube for the other parts.
The "rudder horns" are very caractaristic. Found some info on the "alte news" I tried to make the from steel. I started with a strip of 0.7 mm steel plate, bend it over 90 degrees and flattened on a 1mm steel plate.
 grinded into shape, first with a carborundum disc, later with a diamond one.
In a similar way I made the vertical stabilizers (4 of them!)
 I could bend the 3mm tube by hand, didn't buckle.
 Now I put it together;
 and some detail.
 The weight of the tailboom with stabilizers is 365 gr.
To be continued. |
Posté le: 28/09/2016 18:35 Sujet du message: |
Marvelous building !
you are so equipped ! wood, steel, brasure… you touch at all… gold fingers !!
and the website you join is very interesting for details
Posté le: 28/09/2016 18:46 Sujet du message: |
Posté le: 28/09/2016 18:49 Sujet du message: |
Super chouette cet empennage en tube tout est permis, vive le tube
Philippe26 Psycho Posteur
Posté le: 28/09/2016 19:20 Sujet du message: |
Hi Vincent,
If having changed tube thickness has solved your problem, perfect.
What a great job !!!
Wonderful, as said by another guy, you have golden fingers.....
Friendly
Posté le: 28/09/2016 19:50 Sujet du message: |
C'est chouette, super boulot ![[amen]](images/smiles/amen.gif)
Posté le: 28/09/2016 20:44 Sujet du message: |
Absolute Spitze ![[baaave]](images/smiles/baaave.gif) |
Posté le: 28/09/2016 22:55 Sujet du message: |
Thank you Sebastian, Pat, Vincent, Phillippe, Jose und Johannes for all the nice comments!
I need it a bit, burnt fingers need some TLC
Next is the nacelle and steering cables, it is a very peculiar construction! Bolts, steel, wood, cables I am not complaining, I enjoy it!
About the website "alter news" there is nothing new on it. There happened something with this wonderful project which I don't understand.
I forgot one picture, this is also an enhancement of the Hans Disma one
 This gives a good idea of the rudders.
To be continued! |
Posté le: 29/09/2016 09:11 Sujet du message: |
nickel
Dominique |
CHAUSSEBOURG Maniaco Posteur
Posté le: 29/09/2016 14:05 Sujet du message: |
Beautiful work! Congratulations
LDC |
Posté le: 29/09/2016 16:24 Sujet du message: |
Merci Dominique et Pierre pour votre encouragements!
Vincent |
Posté le: 12/10/2016 10:41 Sujet du message: |
Bonjour a tous,
Last weeks I did a lot of different things. I started with the tailplanes, there was a lot of slop in the vertical ones, so I put an aluminium shim in the tube
 Beercans can be very useful!
Next was the pin to hold both the vertical tailplanes together. I drilled and reamed a 1.5 mm hole through both tubes, used a nail as a pin and with a small clip from 0.6 mm steel secured it.
I also made a support for the seats in which all the rc equipment was installed. It is fixed with two M3 bolts directly to the rear vertical strut, the wing warping force will be just there. In the front of this support are the servo's for the tailplanes and tow hook.
 Here is an overview picture how it fits together. I also changed things at the nacell itself, put in vertical stiffeners (1,5 mm stainless steel, bike spokes) otherwise I think the nacelle will be deformed when I put the diacov on.
 Made from the same material half loops for apertures for the struts and ruddercables. Made a support for the aerotow hook (was not in the real thing and I will make a catapult hook in the skid)
All the different parts etc, also the lead ballast (550gr, flat lead epoxied together) and battery pack. I also replaced the diagonal wooden struts in the front by tubes. Later it will be covered with 0.6mm ply.
 and when put together will create the fuselage
To be continued,
Vincent. |
Posté le: 13/10/2016 10:07 Sujet du message: |
Salut Vincent !
Posté le: 13/10/2016 12:42 Sujet du message: |
Salut Frédéric,
Merci pour les compliments!
The construction is a bit unconventional and I am not used to it ; wood with metal and bolts, it takes a lot of time!
Vincent |
hb Accro Posteur
Posté le: 13/10/2016 18:30 Sujet du message: |
Bravo pour ce superbe boulot de formage et de soudure
Bruno |
Posté le: 13/10/2016 23:25 Sujet du message: |
Merci beaucoup pour les encouragements Bruno!,
Yes, it's a strange "contraption" and I try to build it as much as the real thing. I sometimes forget that it was build in ten days! It looks a bit like he used the same idea as the FG 1 and made the nacelle, to get les drag obviously, as a kind of bow or dome tent ( the first one??).
It is informative to look at the first photo of this story to see how this glider was transported , in parts, on a small truck
Vincent. |
Posté le: 20/10/2016 14:29 Sujet du message: |
Bonjour a tous,
A couple of weeks ago I discovered at "The alte news" that in the WWI fokker a tear shaped tube was used
 So I like to replace the wooden diagonal struts into metal ones and I tried to make it from 6mm X 0.5 mm tube, covered with 0.6 ply. First I soaked the ply with boiling water, gradually folding it around the tube
 After a couple of days it was nicely in shape.
 Covered the clamping battens with tape
 , needed some washing pegs to keep the very slippery battens in their position, put thick cyano on it and pressed it together, just as before. Result when dry
 I still want to pour in epoxy resin, so the ply can't come off!
Next the wing tip handles, this is very characteristic one the real thing!
 From 4mm tube with steel cable to prevent buckling I bended two handles
 and soldered verticals at it. Closed the open ends with pieces of mild steel, in one a M2,5 nut, which of course was filled up with solder....
 At the same time I made wing skids from 3 layers 2mm spruce and sanded it in shape
Next was the bottom of the nacelle, I have only an idea how it was constructed. It looks more like a tent! I guessed he put a steel cable round the wing and a steel cable round the struts of the main skid
 I can't make that with diacov, so I tried to make a thing on which I could glue the diacov. Between the struts I will try to put steel wire. Look at the photo's, I made three, now I hope got a good one.....
 laminating;
 Third attempt;
 Hopefully it will look OK with diacov!
To be continued,
Vincent |
Posté le: 22/10/2016 13:48 Sujet du message: |
Bonjour a tous,
Already quite some time I wanted to make a try run putting the plane together. I only needed attachments for the struts between the wings.
From the same mild steel 0.7 mm plate I made a "U" shaped profile, on which I solderded a M4 nut. Of course the solder ran into the thread, but a tap solved the problem . After the wing is covered, I will put a short lenght of M4 in it (not throuh the spar) and glue in the nut. I don't want to weaken the 8mm spar with a 4mm hole.
I had the plan to solder the rigging gear at the struts, the struts itself go over the M4 bolt and secure it with a spring steel clip. Sometimes you are short of hands...
Now I could put it together
 The wings aren't straight at the foto's, but that will be OK with the rigging installed.
To my big relief it felt quite rigid, I am still concerned if the wings can be warped after covering, hope they will!
Now I am slowly worrying how it will fly!
Vincent. |
Posté le: 22/10/2016 14:07 Sujet du message: |
only one word : marvelous !
respect of details (you have chance of a lot of pictures)
PS : il fait beau outre manche
Posté le: 22/10/2016 14:24 Sujet du message: |
Thank you Sebastian!
It is nice to figure out all the small things, it takes time, but it gives me a lot of satisfaction! At this moment we are guessing about the colour of the metal parts, with Hans Disma and the Fokker heritage, must it be khaki (more or less the standard colour), or grey (which the Fokker heritage found on other Fokkers). When looking at the black and white pictures I think, maybe it is grey....
Of course, when the painting is finished, the right colour will show up
Vincent |
Posté le: 23/10/2016 15:16 Sujet du message: |
Citation: Sometimes you are short of hands...
I understand, if you are drinking continuously a can of beer!
In the meantime we are looking at your constrcution with a lot of admiration.
Good construction.
Harold |
Posté le: 23/10/2016 18:05 Sujet du message: |
Hello Harold,
Sorry for giving that impression! I needed a can for the shim in the rudder and when I need something for support or as a tool, I grab the first thing that I can use. It's always a but messy in my workplace
Thanks a lot for your comments!
Vincent. |
Mad Doc Accro Posteur
Posté le: 02/11/2016 13:32 Sujet du message: |
Sensationeller Bau!!! Ich bin schwer beeindruckt und will jetzt auch lernen wie man Hartlötet!
Liebe Grüße,
Christian |
Posté le: 02/11/2016 14:37 Sujet du message: |
Posté le: 06/11/2016 23:47 Sujet du message: |
Danke Christian et merci Christian pour les comments !!
I went on, it's a funny plane, an awful lot of small pieces, which all should fit, before it's getting painted, looks like not much progress and just not knowing what to do next, I did a lot of small things first.
In the wing is internal cross rigged, which I discovered on the photo of the Hans Disma collection, this is a close up:
I made a non functional rigging of quite weak stainles steel wire with plastic coating, from a jewellers shop,, one long wire with a spring to keep it straight.
 I also made a trailing edge from 0.6 mm solid steel wire
I put a small metal plate at the end, to prevent it pulling through the wood. I also put a small extra stringer near the trailing edge, you can see it also on the Hans Disma photo.
Now the seats; on this picture there is a very small part of the seat visible, but a lot of the controls (coming up)
 but on Alter News I found chairs which look like the standard Fokker seat.
From sheet aluminium (this time a shaving gel can, about 0.4mm thick) I cut and hammered two chairs. They will be covered with diacov later and get a cushion.
 Because this plane has a very visible interior and not much instruments (just a sort of anemometer) I tried to make a neat steering stick. It is a big one (maybe the wing warping needs a lot of force?) A close up from the nacelle;
 giving some ideas how to make one.
 With springs I tried to keep the wiring straight and making it possible to move the stick.
Just in front of the rudder pedals I made a ply "bulkhead" to keep the ballast and battery compartment out of sight.
Just the wooden frame with controls and chairs;
An sideview from the interior, the warping servo is missing and the steering cables will be much more simple!
To be continued, Vincent |
Posté le: 07/11/2016 09:54 Sujet du message: |
nickel ![[good]](images/smiles/good.gif)
Dominique |
Posté le: 07/11/2016 11:27 Sujet du message: |
C'est compliqué… mais réaliste et fonctionnel
how much cannets you drank to make it ? don't forget to paint the seats very good idea !
Posté le: 07/11/2016 12:04 Sujet du message: |
Bonjour Dominique et Sebastian, merci beaucoup pour les comments!
Les sieges sont fait du'n bombe de "gel de rasage" c'est beaucoup plus epaisse que le materiel des cannettes de biere etc.
The idea using that, was in the book "Zen and the art of motorcycling maintenance" ,
I have alredy got the paint!
Vincent. |
Posté le: 09/11/2016 13:38 Sujet du message: |
Vincent, Was soll ich sagen???
Deine Art zu bauen macht Spaß zuzuschauen!
Ich werde ja leider nicht in Vauville dabei sein können, hoffe aber diesen Flieger mal sehen zu können!
Liebe Grüße,
Christian |
