Fokker FG-2 - Congrès 2017 Vauville
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> Constructions Métalliques
Âge: 59 Sagittaire
MessagePosté le: 16/04/2017 15:00    Sujet du message: Répondre en citant
Entschuldige Vincent das ich mich erst heute melde:
[amen] [amen] Dein erster F-Schlepp ist super geworden :
Herzlichen Glückwunsch [amen] [amen]
Weiterhin tolle Flüge mit schönen weichen Landungen [clap] [clap]
Liebe Grüße Johannes
Âge: 68 Poissons
MessagePosté le: 16/04/2017 19:16    Sujet du message: Répondre en citant
[clap] [clap] [clap] belle machine
Signé les copains
Âge: 72 Vierge
MessagePosté le: 17/04/2017 10:17    Sujet du message: Répondre en citant
Danke Johannes, ja ich war ganz erleichtert das der FG gut geflogen hat Very Happy
et merci Pierre, le FG c'est certainement une machine!
Je continue en Anglais,
To start with, it was an relief and at the same time very rewarding to see th FG flying, she is so translucent, a bit archaic, we enjoyed it very, very much!!
After these first flights it was obvious that the cg was too for forward. Somewhere the fact was in my mind that the main girder was on 30% and I put the cg there. Later I discovered that the girder was on 25%, so I had to take out some lead. I figured out that about 220 grams less was sufficient.
No easy acces, the camera is much smaller than my head!
Two holes in the diacov to take the bolts out
Some wrenching because the lead was glued with epoxy
and with tweezers put the nuts back
Th cg was now at 30%, hopefully that is right, at least I know how to get out more!
There was another thing that worried me, the wiring or rigging of the wing warping. I made a sketch to clarify things
as you can see there are two ( I came up with the names, maybe ther are better names for those wires) "control wires" ataching the servo arm with the upper wings, and one "connecting wire" between the lower wings via a pulley inthe center just under the upper wing. If there is a failure of one of the control wires, the plane is uncontrolable, its only possible to roll to one side and not back. That was a worrying thought! When testing stationary sometimes the quicklink on the servo arm snapped out and after the handlaunches there also unsnapped other quicklinks. I didn't trust the quicklinks 100%. There are other quicklinks with locking plates
(top on the picture) put the locking plates are so tiny, they will get lost, I am afraid. I made a spring of 0.6 steel wire, around a 4mm drill and snipped off pieces of a couple of windings, which you can slide over the quicklink (bottom) It looks reassuring, hopefully they do there job.
I could not use this on the servo arm, because of the full throw I need there. I modified the quicklinks into more permanent linking
The bushes are long enough to give free rotation when the M 2 nuts are fastened. The metal strips are ment to give a better load distribution on the plastic of the servo arm.
I use these locking rings on some important quicklinks of the other rigging, so I get a bit more trust in all those wires!
One advantage of the wiring and floppy wings is the following thing; by adjusting (shorter) the "connecting wire"it is possible to introduce a smaller angle of incidence at the tip, to get better stall charasterics.
To be continued,
Vincent.
Mad Doc
Âge: 42 Scorpion
MessagePosté le: 20/04/2017 12:48    Sujet du message: Répondre en citant
Ich hab auch lange nicht reingeschaut, staune um so mehr!! Toll! Super Erstflug-Video!!!!
Holland ist natürlich ein sehr toller Ort um zu schleppen, Ihr habt dort so viel Platz und gerade Flächen... und nebenan direkt eine Wasserflug-Startbahn...
Herrlich!
Liebe grüße,
Âge: 72 Vierge
MessagePosté le: 20/04/2017 15:20    Sujet du message: Répondre en citant
Hallo Christian,
Ja, die Erstflug war schon!! Doch immer ein bisschen "No guts no glory".
Ich hatte immer geglaubt das in Deutchland mehr Platz um zu fliegen wahre, im Holland ist das sehr schwierig irgendwo platz zu finden, so wir sind ganz froh mit diese Stelle. In eine woche hatten sie die Graben gemacht und dan gab es Wasser! Und mit Wasser ist das genau dasselbe wie mit Baume, die Modellen ziehen dahin Sad .
Liebe grüße,
Âge: 46 Gémeau
MessagePosté le: 23/04/2017 21:43    Sujet du message: Répondre en citant
Salut Vincent,
Un grand bravo ! Il est superbe ton biplan, la silhouette et la transparence waouwww, magnifique ! [amen] [amen] [amen]
Âge: 72 Vierge
MessagePosté le: 24/04/2017 13:44    Sujet du message: Répondre en citant
Salut Lolo,
Merci beaucoup !Very Happy Very Happy
I am also very pleased with the transparancy of the wings, the 140+ "nervures aux baquettes" had their effect!
Âge: 72 Vierge
MessagePosté le: 07/05/2017 18:50    Sujet du message: Répondre en citant
Bonjour a tous,
I did some small things, to make the quicklinks less visible I blackened them chemically with Bernax 540 of which I happened to have some.
rinsed them with water.
Then I discovered a problem; on which spot could someone hold the plane when the catapult (sandow) was under tension?
I think the rudders are to weak, the attachment for the horizontal stabilizer is also a bit weak, besides there is no room for one hand. Rigging wires all over the place!
So I made a device, or better said a contraption to hold the glider in place with the catapult under tension, with a release hook.
I used a modified standard release hook connected with a 8mm stainless steel tube attached to a wooden handlebar. A 1mm stainless steel operating wire with a rope loop as a trigger.
On the plane I made also a demountable loop, attached to 0.6 mm steel wire, which was connected to one of the wing struts.
Here Sjoerd demonstrates how it should work (I tested it at home with 15 KG tension and the plane stayed horizontal too)
Today Rob towed the FG 2 again and it performed well.
The CG looks OK, the elevator is just a degree or 2 up, the plane was really flying!
Âge: 59 Sagittaire
MessagePosté le: 07/05/2017 19:26    Sujet du message: Répondre en citant
Hi Vincent,
spitze wie Du solche Probleme löst -
super Idee [clap] [clap]
Âge: 55 Scorpion
MessagePosté le: 07/05/2017 19:27    Sujet du message: Répondre en citant
hello Vincent,
Very interesting your system of trigger of dropping for the plane difficult to block on hands… !! [clap]
Âge: 72 Vierge
MessagePosté le: 07/05/2017 21:54    Sujet du message: Répondre en citant
Hello Johannes und Sebastian,
Thanks! Hopefully this thing works properly at Vauville!
fabplane56
Âge: 43 Balance
MessagePosté le: 04/07/2017 13:42    Sujet du message: Répondre en citant
beautifull model , and the work on it is simply awesome ! i wish i had the skill to make a such model [amen] stickers voiture
Âge: 72 Vierge
MessagePosté le: 04/07/2017 16:07    Sujet du message: Répondre en citant
Thanks a lot for your comment!
About the skills, its mostly a matter of practice...
Âge: 56 Verseau
MessagePosté le: 29/07/2017 23:04    Sujet du message: Répondre en citant
Je ne me lasse pas de regarder ta vidéo , merci pour les images elles trouveront leur place sur la vidéo Very Happy
Quel bonheur d'avoir vu voler plusieurs fois ce Fokker sur une des plus belle pente de France [baaave] ,
Âge: 65 Vierge
MessagePosté le: 30/07/2017 08:27    Sujet du message: Répondre en citant
alors la un très grand bravo c'est du grand art [clap] [clap]
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> Constructions Métalliques Toutes les heures sont au format GMT + 1 Heure
Page 13 sur 14
