bocorvin Maniaco Posteur
Posté le: 25/11/2016 11:19 Sujet du message: |
Merci Phillippe et Harold pour les comments! Oui j'espere il est fini cette annee. Dans l'hiver et le printemps je doit faire les pilotes et aussi le instrument (seulement le anemometre )
I hope to finish and test the wingwarping this weekend, I'll keep my fingers crossed and I will post that of course!
Vincent. |
Posté le: 27/11/2016 00:05 Sujet du message: |
quelle belle construction Vincent vivement la suite.
Mad Doc Accro Posteur
Posté le: 27/11/2016 12:41 Sujet du message: |
Vincent!!!! Was machst Du denn da???? Du sollst doch nicht besser uns schöner bauen als das Original war!!!
Ich bin wirklich schwer beeindruckt, unbedingt muss ich den Flieger mal live sehen!
Liebe Grüße,
Christian |
Posté le: 27/11/2016 18:14 Sujet du message: |
Merci beaucoup Michel pour les comments Und Christian, das war schon!,deine commentar hatte mich sehr viel spasz gegeben!!!!!.
To not disappoint you both, I'll give a small preview
https://youtu.be/B5Fki3LSL3E
This is a very short video of the wingwarping, a lot of wiring is temporary, so there is quite a lot of slop, will be better, but I think basically it's working
to be continued,
Vincent |
Posté le: 01/12/2016 15:49 Sujet du message: |
Bonjour a tous,
I started with covering the rudders and tailplane, looking again at "Alte news" for details used by Fokker
The diacov went on very nicely, especially round edges.
After finishing this I went for the nacelle, hoping for the best. First the rear upper part of the nacelle,
Put in the ballast (800 grams, painted white), so I hope it will be less visible, containing the battery pack. Then I could do the underside.
Now I could cover the topside of the nacelle
Now the rigging, I had a pair of pliers which came in useful!
some shrinking tube
I placed the clips at the struts , so I can dismantle it and it is less obtrusive (I hope).
detail of the rudderhorns
Suddenly it's looking quite complete
The wingwarping was tuned a bit and I made a short video
https://youtu.be/a8YtED_fWvY
When putting the plane vertical you get a nice view of the bottom.
I have a question; On the short films from the FG 2 and the foto's I get the impressing that there is no canvas at bottom, so I left it open. Besides that it is practical I can image that it was made that way, but maybe there is some other info!
Next is the internal fuselage rigging, the wingtip handles and skids and finishing the interior. Last but certainly not least the pilot and passenger.
To be continued,
Fotor Stagiaire Posteur
Posté le: 01/12/2016 16:06 Sujet du message: |
I've seen this project in real life today, and it is absolutely stunning! Well done so far Vincent.
Hopefully I can be present during the first flights, so I can make a nice movie and photo's. |
Posté le: 01/12/2016 17:04 Sujet du message: |
Thanks a lot for your nice comments Raymond!
Yes I hope you will be there with the first flight to make shots and film, you did a splendid job with the Nemere video!
Vincent |
Posté le: 01/12/2016 17:15 Sujet du message: |
Marvelous and speedy building
tu vas teinter l'entoilage ?
Posté le: 01/12/2016 17:26 Sujet du message: |
c'est du très très beau travail bravo
Dominique |
Posté le: 01/12/2016 18:09 Sujet du message: |
Merci Dominique et Sebastian pour votre commentaires!
Helas, le FG 2 est completement sans teinte . C'etait une travail tres vite par Fokker, l'avion est construit en dix jours! (on a dit), pas de temps pour peinture , je pense. Seulement le chiffre 4 sur l'empannage vertical droite.
J'espere de faire le pilote et son passagiere un peu plus couloureux!
Vincent. |
Posté le: 07/12/2016 16:15 Sujet du message: |
Bonjour a tous,
Today I made the internal rigging of the tailboom. On the website of Paolo Severin is a method described to make the inetrnal rigging, which is very usefull. When I visited the Aviodrome I could see how Fokker does this on his "Spin", his first aircraft,
He made his own "bushes, tubes?" from wire and I tried to do the same.
I wrapped 0.5 steel wire around a core of 1mm steel in a drill.
cut it in short "bushes"
Put it under tension when I put it through the other hole..
fold it around and put the bush on it
Sometimes it was hard to reach....
The tailboom became incrideble stiff, I hope not to stiff, when I touch a wire accidentally it sounds like a guitar
some detail;
to be continued,
Vincent. |
Posté le: 07/12/2016 23:08 Sujet du message: |
Hi Vincent,.
einfach genial wie Du baust - Spitze
LG Johannes |
Posté le: 15/12/2016 16:46 Sujet du message: |
Merci Johannes for the nice comments!
I tried to put all the rc components out of sight under the seats and more or less demountable. Without ;
and with the rc components/ seat supporting structure
The steering stick and rudder pedals ready for mounting;
The springs are only to keep the wires straight, its all not functional
The backrest of the seats covered with diacov and painted with humbrol
The cushion was made from 3mm balsa covered with leather from an old purse (nice thin leather)
and temporarely in place
Now I have to make a pilot and a passenger and then I can make the harnesses.
To be continued,
Vincent |
Posté le: 15/12/2016 17:42 Sujet du message: |
You sacrificed a purse ! I hope that you hidden a coin under the seat as carries happiness as hold traditions
Toujours aussi astucieux et mécanique comme réalisation
Posté le: 16/12/2016 10:31 Sujet du message: |
Dear Vincent,
You have steel nerves!
Good continuation.
Harold |
Posté le: 05/01/2017 14:32 Sujet du message: |
Hello everyone,
First, thankyou Sebastian and Harold for your comments! It took some time because I had a bike accident followed by influenza, it took some time!
I went on putting the grabrails?? and wingskids at the wings. I tried to avoid Philips screws, so I used M2 bolts and nuts
A small pin went through the skid at the front end to avoid rotation, I hope its flexible enough not to break.
The grabrails are fastened with a M3 bolt through the maingirder in the front and a screw at the rear.
In the meantime I worried myself how to transport the whole lot.
There are 8 cables per side and kinks (coudes?) are a real danger. It is just a sailingboat with the mast lowered. So after lots of thinking I came up with some "helpthings"
Spruce 8 X 4 mm with pins and rubberbands do the trick, I hope.
Flexible rigging cables, flexible steering cables and rigid rigging, hopefully it will make some noise when flying
With some luck the tailplanes fitted on top
The remaining vertical tailplanes go with the wings.
All the small parts well protected!
Its almost ready, I am working on the pilot and passenger , the anemometer is only just on the drawing board!
to be continued,
Vincent |
Posté le: 05/01/2017 15:16 Sujet du message: |
Absolut Grossartig!!!
Sieht so aus als wäre der Erstflug nicht mehr weit entfernt!
Ich bin ein bisschen froh das ich die Fokker nicht auch baue, so wie ich es mal vor hatte. Wahrscheinlich hätte ich meine dann schon fünf mal verschrottet....
Auch wenn ich nicht in Vauville dabei sein kann, ich würde sie echt gerne mal fliegen sehen...
Liebe Grüße,
Christian |
Posté le: 05/01/2017 16:43 Sujet du message: |
Hello Christian,
Danke!! und Ich hoffe naturlich es einmal for zu fliegen!
Aber Ich erinnere mich deine worte; jedes mal das man das Flugzeug start, bist mann nicht sicher das es unbeschadigt bleibt
Liebe Grüße,
Vincent |
Posté le: 21/01/2017 13:36 Sujet du message: |
Hello everyone,
I started with the pilot figures, got a drawing and scaled it down to 1: 5, glued it on card to make templates
, cut them out in 10 mm balsa, which I doubled to get more or less the right thickness
For the knees and elbows I used robart 3.5 mm hinges
The hips and shoulders should rotate in all directions, so I made joints with double elastic band.
To get the right amount of freedom in articulation, I rounded the inside of the joints.
You can just see the place where I put a pin (red arrow), it goes through the middle of the big hole, so the elastic band goes round the pin. I use a double bended steel wire to get the elastic cord in place
When the clothing is finished, I will put a knot in it! The pilot was a bit thin, so I glued an extra 5mm balsa on his chest.
To see if they fit I compared it with the real thing:
I also doubled th Diacov on the nacelle, to make it a bit less transparant.
This picture, which I recently found, gives a good idea of the harness he used
The points where the hip belt is attached is just visible
On this photo you can also see how the shoulder belt is positioned. The belt itself is very broad, scaled down I guessed about 14mm. I could get 14mm wide, black elastic band, so that problem was solved. I made the anchoring plates from 0.5 mm aluminium (from a can)
, made a jig from steel plate. A lot of plates, sprayed white.
Bolted with M2 just behind the seats ( the shoulder belts have each one point, not on this photo)
I had to take this unit out again
The buckles and the belts secured with a clip
The pilot and passenger went to my sister Hans who is going to make the clothes (I can't wait!!)
Quite unexpected I started with the heads, made from super sculpey. tI tried to make the pilot look like Anthony Fokker
, I altered him a bit and made the passenger, which looked a bit less optimistic
Both will be wearing caps, so the ears will be covered.
The heads are baked, but not yet painted, next thing to do!
Will be continued,
Vincent |
Posté le: 21/01/2017 13:41 Sujet du message: |
Amazing how you make everything yourself |
Philippe26 Psycho Posteur
Posté le: 21/01/2017 13:58 Sujet du message: |
Yes absolutely,
That's the true modelling.... congratulation.
Your two passengers look great !
Posté le: 21/01/2017 14:54 Sujet du message: |
superbe travail
Dominique |
Posté le: 21/01/2017 19:03 Sujet du message: |
SUPERBE construction ,et beau pilote
Posté le: 23/01/2017 15:35 Sujet du message: |
Bonjour a tous,
Thanks very much Fotor, Philippe, Dominique and Michel for your encouraging comments!
Just when I more or less finished the heads I found a very useful "class" on youtube how to model heads in sculpey clay, worth to take a look at!
https://www.youtube.com/watch?v=BSbSX-rDYLM&t=38s
Vincent |
RichardP Accro Posteur
Posté le: 23/01/2017 16:05 Sujet du message: |
excellent tuto
thank you
Posté le: 26/01/2017 16:32 Sujet du message: |
Hello everyone,
The FG-2 was only equipped with the Wilhelm Morrell anemometer, very well described by Vincent Becancon in his article about the Mira 3.
Here just visible on the right diagonal strut.
I gave my friend ADRI (who already made the rib templates and all the small ply stuff for the ribs) the plans and asked him if he thought 3D printing was an option. He texted me; just wait!
I had a lucky day! After some time the photo's came in!
So ADRI made this anomemeter completely!!
(I only painted it)
The dial is the download of the Mira 3
I was very pleased with his great effort!!
Now I went on,I only had to make the mounting thing and paint it (Humbrol matt grey)
A small video,
https://youtu.be/3INhTQuJVMk
Thank you very much Adri, this was a tricky thing to make!! and I am very pleased with it!!
To be continued,
Posté le: 26/01/2017 17:01 Sujet du message: |
Ca me rappelle des souvenirs. Bravo Vincent, superbe ton anemo WM
CHAUSSEBOURG Maniaco Posteur
Posté le: 26/01/2017 18:00 Sujet du message: |
Beautiful work!
LDC |
Posté le: 26/01/2017 18:03 Sujet du message: |
Hurray for Adri !!!
What a perfect job !
I wonder if it works really
O.K. I'm out !!!
Posté le: 26/01/2017 18:36 Sujet du message: |
superbe travail,bravo
Dominique |
