Hibernatus Fidèle Posteur
Posté le: 23/02/2021 10:24 Sujet du message: |
Salut
Belle réalisation pour ces coffrages.
@+Christian
Posté le: 23/02/2021 14:32 Sujet du message: |
Comme d'habitude, de beaux modèles et une belle construction. Bravo !
bocorvin Maniaco Posteur
Posté le: 24/02/2021 21:31 Sujet du message: |
Thanks for your nice comments,
Vincent (DB) |
Posté le: 06/03/2021 12:26 Sujet du message: |
Bonjour a tous,
The nose of the fuselage is a challenging job. It's important how the fuselage looks, so I hope to do well
I had roughly sanded the nose into shape and I marked the strips on it with a pencil
At the connection to the cockpit cover they follow the round frame shape. Further forward, the strips flatten so that they can be bent towards the tip of the nose. There is no double bending
I came up with the idea to mark the strips with a small router, so you can sand some without sanding away the marking.
Strip by strip, the nose is covered. For these strips I use veneer instead of ply and I glued them with thick cyano
The result
The fuselage is now 1085 gr with 3 servo's and receiver.
Now I am starting the preparations for the wings and the fairing wing/fuselage.
Vincent (DB) |
ThomasF Incurable Posteur
Posté le: 06/03/2021 13:36 Sujet du message: |
Sehr schön Vincent, ich hoffe wir können im Sommer wieder zusammen fliegen.
Thomas |
Posté le: 06/03/2021 14:48 Sujet du message: |
Danke Thomas and ja, dass hoffe Ich auch
Vincen(DB) |
Sed Maniaco Posteur
Posté le: 07/03/2021 14:21 Sujet du message: |
Superbe Vincent !
Et après la teinte, on ne verra plus de différence entre le CTP et le bois de placage .
Serge |
Posté le: 07/03/2021 18:59 Sujet du message: |
Merci beaucoup Sed ,
You are right, there is not much difference in colour after colouring it. I might make it a bit darker.... This is my Gull
When the glider leaves the factory, its quite light, but after a year or two they become much darker.
On this Petrel there is a big difference in colour. Maybe I can give the nose a darker colour? I think about it
Vincent (DB) |
Posté le: 07/03/2021 20:25 Sujet du message: |
Hi Vincent,
das Holz hast du toll bearbeitet
Posté le: 13/03/2021 14:58 Sujet du message: |
Danke Johannes .
Jetzt die Flugel, ich gehe weiter in English ,
The profile choice I found difficult, the real King Kite had a profile NACA 23021 which looked quite symmetrical. The profile and thickness determine the "looks" of the aircraft and so I ended up with HQ 2.5 with a thickness of 12% decreasing to 10 at the tip. With the flaps (and the ailerons, not prototypical) I can make more camber . With Devwing I drew the wing
Adri was kind enough to mill the ribs and the web plates. The root ribs in 2mm plywood and the rest in 2.5mm medium-hard balsa.
With the program “Calculdelongeron” I calculated the main spar, 24X4mm spruce on top and bottom at the root to 2x10mm at the tip. Should be able to take 10G, not including sheeting. By the way, the wing is completely sheeted with 0.6mm plywood, like the real one. I had previously made a glass / epoxy wing joiner with dihedral that fits in 20x20mm aluminum square profile. Because it has a gull wing, I made a building board with the gull angle and laminated the spars in that angle too.
building the wing
Servo holder, all 4 made in one go
All the web plates glued, left open at the root. So the space between the aluminum square and the main spar can be filled with epoxy /micro balloons.
It's starting to look like a wing!
I'm going to build the other wing now.
Vincent(DB)
Olli Incurable Posteur
Posté le: 14/03/2021 22:24 Sujet du message: |
As usual, great jobs
Posté le: 17/03/2021 10:12 Sujet du message: |
Nice construction
Good luck for the future
@++ Christian
Posté le: 19/03/2021 20:42 Sujet du message: |
Danke Olli, merci Philippe et Christian, pour votre comments gentils
The assembly of the left wing went without delay
Now I could fit both wings on the fuselage. Then I discovered a huge mistake!!! In a kind of having a blind spot I had made the dihedral in the wing equal to the dihedral of the wing connector; ERROR, that had to be half of that , oops.
After some bad moments , I thought better now, than much later in construction.
So I cut out the curvature in the top spar
and with my powerfile I beveled both sides 1 in 10.
I changed the angle in the build board (extensively checked now!) and glued two 1X10mm battens under the topspar to get a stable situation .
. I made suitable pieces of 2x10 mm spruce and glued it between the spar with 24h epoxy with wood dust as filler.
At least now The King Kite looks good, just a few pictures in the garden. .
Vincent (DB) |
Sed Maniaco Posteur
Posté le: 19/03/2021 20:51 Sujet du message: |
Bonjour Vincent,
Ouahhh, il est superbe tout monté avec les ailes en mouettes !
Tu travailles vite et bien , et à ce rythme, il sera bientôt prêt à voler !!
Tu as déjà choisi la teinte ?
Serge |
Posté le: 19/03/2021 21:00 Sujet du message: |
Bonjour Serge,
Merci pour votre comments!
There is a lot of work to be done!
I am not sure if I choose the light colour as on my Nemere and Gull, or choose for a darker "plus antique "
Time enough to consider. And I am very curiuos what the weight will be. Patience please
Vincent (DB) |
Posté le: 19/03/2021 22:10 Sujet du message: |
Hello Vincent !
always you have solutions
ça va faire un joli modèle ! Les ailes ont l'air d'être très étroites par rapport au volume du fuselage… mais j'imagine que les proportions sont respectées.
Encore bravo et au plaisir de suivre ton avance
Posté le: 19/03/2021 23:33 Sujet du message: |
Hello Sebastian and thanks for your words!
I was glad finding that solution
The dimensions of the wing are prototypical, in the model; wingspan 395cm, chord at the root 30cm at the tip 12cm.
Maybe its just the photo that is gives the impression.
The ailerons are next and they are rather narrow.
Vincent (DB) |
ManfredNeu Accro Posteur
Posté le: 20/03/2021 11:16 Sujet du message: |
Hallo Vincent,
es tut gut, dass hier auch einmal von Missgeschicken berichtet wird . Ich könnte damit wohl ein kleines Buch füllen . Jedenfalls die Arbeit am Modell ist grossartig. .
Manfred |
Posté le: 21/03/2021 12:06 Sujet du message: |
Hallo Manfred,
Danke fur die heilende Worte
Ohne Fehler gehts leider nicht, aber diese Fehler war nicht notig
Vincent(DB) |
Posté le: 23/03/2021 14:29 Sujet du message: |
Je suis toujours surpris et épaté par les solutions que tu trouves. Bravo !
Posté le: 25/03/2021 10:49 Sujet du message: |
Hi Vincent,
Goodjob, it's superb !
Friendly,
Posté le: 27/03/2021 20:48 Sujet du message: |
Merci Philippe et Lolo, J'ai bien besoin de vos mots apres le probleme avec le "V" dans les ailes.....
Now that the basic structure of the wings was ready, it was time for the ailerons and flaps. First the ailerons.
I found differences between the ribs in the drawing and the photos
In the drawing, the aileron even seems to consist of two parts, of which nothing can be found in the photo. I therefore decided not to divide the aileron in two parts. Another problem was that the aileron was “enclosed” on both sides. I therefore chose the same hinges as the horizontal stabilizer. The aileron remains removable. With the help of a curved strip you can unlock all hinges at the same time, place the aileron, and then remove
the strips.
After cutting off the aileron from the wing, I realized how long and narrow it was, 115cm long and 4.5cm wide.
The profile choice did not help either, unfortunately. The aileron was therefore only 6-7mm thick. I also became convinced that I had to control the aileron in two places and luckily was able to find place for an extra servo in the wing.
The balsa ribs in the aileron were very thin and fragile. So I replaced the balsa ribs with 2mm solid spruce, took out one, replaced it with spruce, went on to the next, so that I kept the dimensions
I wanted to make a plywood D section for the nose of the aileron. With boiling water I bent U profiles of 0.6 plywood around a 6mm tube and let them dry. I slid the aileron skeleton into this profile and clamped it to a plate with a batten. I had covered both the batten and the board with tape, in order not to get adhesion with glue. I also built in some twisting. I set the plank upright and dripped thin cyano between the rib skeleton and the plywood U profile.
. Now I had a much firmer unit. I further built up the rear frame with 0.6mm plywood and sawed, cut and sanded
the U profile and the TE into shape. Then I added capstrips and the aileron was finished roughly, still needed some sanding.
Vincent(DB) |
Posté le: 28/03/2021 19:38 Sujet du message: |
Posté le: 29/03/2021 10:30 Sujet du message: |
Gute Idee, das mit dem Verkleiden der Querrudernase , und einfach ein klasse Modell .
Manfred |
Posté le: 29/03/2021 20:06 Sujet du message: |
Merci Lolo und Danke Manfred,
Das Idee um dass so zu verleimen ist aus Not geboren
Veileicht hatte es auch met Weissleim geklappt, aber das sinds zoviel oberflache und so hats einfach geklappt.
Es fehlt noch etwas nacharbeit...
(hoffentlich nicht alzu viel Fehler in mein Deutch )
Vincent (DB) |
Posté le: 09/04/2021 19:52 Sujet du message: |
Bonjour a tous,
After I built the second aileron, I went on with the flaps. These are much shorter (56cm) than the ailerons and completely sheeted. They are even thinner than the ailerons, less than 6mm thick. So I liked to sheet them in one go. I took a strip of 9cm wide, 0.6mm plywood, and bended it around a 6mm round rod, whilst pouring over with boiling water, see also this video https://www.youtube.com/watch?v=KoZUbuMlBck (sorry, Dutch subtitled). Then I clamped and let it dry
Also on the photo is the backbone consisting from the ribs, main spar, back frame with balsa filler strips. It is a very weak skeleton. By fitting this skeleton into the folded plywood, I could mark, cut and sand the plywood.
Covered the structure with PVA
and clamp it with a 10X10mm batten en strps of 4mm ply.
After the glue had dried I could fold the plywood “open”, and I drilled 1mm from the inside pilot holes so that I could make the openings at the hinges and rudderhorn later.
I smeared the top of the ribs with glue and clamp the whole thing together, just like before.
With a Dremel I made the openings for the hinges and after some adjustments it fitted neatly into the wing.
Vincent(DB) |
Posté le: 22/04/2021 13:34 Sujet du message: |
Hello everyone,
I wanted to keep the operation of the ailerons and flaps simple, this time not with pull / pull wires, as with the Gull. The pull / pull cables in the wings are nice, but weigh a bit more and there is a bit more friction which is not good for the precision, unfortunately. I thought to make a pull / push rod on the bottom and a dummy control on the top. Unfortunately I couldn't figure out how the flaps were operated, so I also chose a pull-push rod on the bottom of the wing. On the basis of a photo I tried to estimate the size of the rudderhorns.
I came up with very small horns, I drew them twice too big (by hand ..)
My friend Adri was so kind to CNC quite a few. Afterwards the size seemed quite correct
First I made the dummy control at the top of the wing from 0.8mm steel wire, with a non-functional clip
This rod can move freely in a plastic tube glued to a rib. I made the functioning pull / push rod from an M2 threaded rod with quick links
To remove the aileron (to put the Diacov on) I disconnect the quicklinks, unlock the hinge pins and then I can detach the aileron with dummy rods and all. The flaps only have a pull-push rod at the bottom
I make these from 1mm steel wire with a guide tube against bending. After some soldering I could check the working of the flaps and ailerons, they worked nicely.
Vincent (DB) |
texier Accro Posteur
Posté le: 28/04/2021 18:18 Sujet du message: |
Hello Vincent,
Interesting and realistic tip this dummy push rod
Sylvain.
