ultralajt Fidèle Posteur
Posté le: 16/03/2013 10:18 Sujet du message: |
Last night I work again on my pilot.
I finish the head I started last year and make hands and legs with shoes. All parst are made from SuperSculpey. I baked legs and hands at 130°C for 20min and head for ~40min.
Now I must make some refinements on the parts as now that are solid, I can use file, knife, sandpaper, to correct all tiny details that went "out of shape" while working with soft Sculpy.
Then parts will be ready for making molds. I will try to use silicone.
Mitja
Never try, never fail....
Posté le: 17/03/2013 11:30 Sujet du message: |
Hi Mitja, nice modeling and thanks for sharing your pattern Funny your tip for coloring the fabric, it's only onion?
Posté le: 17/03/2013 13:22 Sujet du message: |
ok, and after tinting clothes, you can cook onion soup
J.Grözinger Stagiaire Posteur
Posté le: 26/03/2013 15:11 Sujet du message: |
I'm also a pilot doll for my ASW 15 M 1:2.5 modeled from Sculpey Clay, I read here with otherwise silent, but see them selves
Greats from Germany
Jürgen
Gruß Jürgen |
Posté le: 27/03/2013 07:16 Sujet du message: |
Hi Jürgen, nice sculpting what material will you use for the mould, latex, silicone?
Posté le: 27/03/2013 13:23 Sujet du message: |
Hi Vincent, I do not know what I should take, I just study on the differences in the materials
Gruß Jürgen |
Posté le: 27/03/2013 13:48 Sujet du message: |
I tryed some methods and differents material, silicone is of course the best, but more expensive than latex... have you seen this page? http://www.retroplane.net/modelage/index.htm review of all my tests
Posté le: 27/03/2013 15:12 Sujet du message: |
I read this page. Today I had a conversation with the company Kaupo (www.Kaupo.de) they thought I should take silicone when it is more expensive but better. I'm going to order it and report if the first parts are finished.
Gruß Jürgen |
Posté le: 09/04/2013 15:52 Sujet du message: |
Hi Jürgen,
any progress? and you Mitja?
I have updated the page http://www.retroplane.net/modelage/ with all steps of my last pilot for the Nitra3, and at the bottom of the page there is a video of molding
Posté le: 09/04/2013 23:14 Sujet du message: |
Hello Vincent,
I opted for silicone and resin foam will soon begin to form. I'm very excited about your new job, what kind of a foam you use he makes a Good Job.
Gruß Jürgen |
Posté le: 03/07/2013 09:21 Sujet du message: |
Hi Jürgen,
Any news? Did you make molding?
Posté le: 04/07/2013 14:38 Sujet du message: |
Hi Vincent,
I have not done anything yet, find no time to do, sorry.
Gruß Jürgen |
Xav38 Apprenti Posteur
Posté le: 25/09/2013 20:30 Sujet du message: |
Je me suis aussi lancé et ai préparé 4 bustes de pilotes au 1/5 pour mon Musger Mg19. En voici deux (il y a encore du boulot...mais j'y crois !) En faisant faire un devis pour le silicone, la résine et la mousse PU, j'arrive à 130 euros...
Du coup, si ça intéresse quelqu'un, je propose de lui envoyer mes masters en lui rachetant les moules et/ou les bustes PU en retour, ou à lui racheter ses matériaux en rab avant péremption, ou tout autre arrangement gagnant gagnant pour optimiser les coûts. Avis aux amateurs.
Posté le: 26/09/2013 05:58 Sujet du message: |
Juste un avis perso, sur tes bustes tu ne devrais pas mettre les cheveux/barbe, sur celui de gauche c'est une casquette?
Je m'étonne d'ailleurs toujours de voir les cheveux moulés sur les pilotes du commerce, car le rendu en peinture et le relief n'est jamais terrible par rapport à un visage nu sur lequel tu ajoutes ensuite des cheveux/barbes en mousse, filasse... de plus, les cheveux moulés ça fait en général une épaisseur génante pour mettre une casquette
Posté le: 26/09/2013 06:30 Sujet du message: |
Merci pour le conseil Vincent. Oui, c'est un béret à gauche et effectivement il est difficile de rendre la finesse de la chevelure à cette échelle. Je vais donc faire quelques chauves et choisir les meilleurs ! |
Posté le: 26/09/2013 06:36 Sujet du message: |
Ce qui va bien pour modeler, c'est de s'aider de rendus de ce genre http://www.vidarrapp.se/wp-content/vr_male_scetch01.jpg on en trouve plein aec google imags en tapant "face sculpting". Ou avec un logiciel comme Facegen on créé à l'infini des visages, voir même le sien à partir de 3 photos, bon après faut pouvoir le reproduire, mais même si on y arrive pas exactement, on appréhende mieux les volumes à modeler avec ce genre de rendu 3D
Sed Maniaco Posteur
Posté le: 16/02/2019 01:58 Sujet du message: Pilote fait main |
Suite aux conseils de Vincent, je me permets de poster à nouveau quelques photos et explications sur la fabrication du pilote réalisé pour le Pešta Peta-Z 1934.
( www.retroplane.net/forum/viewtopic.php?p=155287#155287 )
Vue d'ensemble des différents éléments.
Toutes les parties du corps sont constituées de blocs de balsa collés puis poncés (je l'admets, assez approximativement).
Les articulations des membres sont faites avec des charnières de type bâton. C'est vrai que ce système ne permet pas de mouvement dans tous les sens, mais cela a le mérite d'être simple à réaliser...
Les mains et pieds sont réalisés en résine à partir d'un moule en latex (en suivant scrupuleusement le post 'Modelage et moulage' de Vincent) dans laquelle j'ai intégré un bout de tige filetée. Pour recevoir cette tige filetée, des manchons ont été insérés aux extrémités des membres.
Ici un bras.
Le bras avec la main en train d'être vissée.
Même principe pour les pieds.
Le buste quant à lui dispose de manchons insérés au niveau des épaules et de l'entre-jambe.
Pour fixer le bras, une vis traverse celui-ci, passe dans le manchon fileté puis continue en passant dans le manchon fileté du buste.
Le buste avec ses 2 bras fixés.
Pour les jambes, le système est identique, à la nuance près qu'une seule visse permet de fixer les 2 jambes au buste. La vis traverse la jambe droite, passe à travers le manchon de l'entre-jambe et vient se visser sur le manchon de la jambe gauche.
La tête est équipée à sa base d'un tourillon qui viendra se ficher dans le trou prévu à cet effet côté buste. Au début, j'avais choisi d'aimanter la tête mais j'ai eu peur que cela ne sois pas suffisant.
Voilà, monsieur est installé dans son siège de pilotage.
Pour être plus présentable, une petite tenue lui a été confectionnée. Ce n'est pas moi qui l'ai réalisée et du coup, je ne dispose pas d'un patron. Le souhait de départ était quelque chose de ce genre-là.
Pour au final arriver à ça.
Voilà pour l'instant.
Pour ceux qui veulent examiner la fabrication d'un pilote plus évolué, vous pouvez consulter le post 'Rubik R-07 Vöcsök' de Michel. Il est vraiment super bien fait.
Bonne nuit à tous.
Serge |
Eric Spore Incurable Posteur
Posté le: 18/02/2019 08:43 Sujet du message: |
Belle realisation. Ne pourrais tu faire une articulation au niveau de la nuque pour eviter que ton pilote ne regarde que les étoiles?
Sed Maniaco Posteur
Posté le: 18/02/2019 12:06 Sujet du message: |
Bonjour Eric. Merci pour ton retour. J'ai déjà corrigé l'angle de la tête mais tu as raison, je vais réfléchir à un système pour pouvoir l'incliner.
Bonne journée.
Serge |
Sed Maniaco Posteur
Posté le: 25/05/2020 05:17 Sujet du message: |
Belle mécanique
Je me permets juste une remarque, je trouve dommage que la plupart du temps, ces pilotes aient les cheveux/barbes moulés et peints
