IS-4 Jastrzab Thomas G.
1, 2, 3, 4, 5, 6, 7
Thomas G.
Âge: 71 Poissons
MessagePosté le: 26/05/2013 10:07    Sujet du message: Répondre en citant
Aujourd’hui, en profitent d’un bref moment d’accalmie, j’ai pris quelques photos d’ensemble :
Thomas G.
Christian_B
Âge: 73 Capricorne
MessagePosté le: 26/05/2013 10:42    Sujet du message: Répondre en citant
You made the best Jastrzab out of the Oldgliders kit!
Congratulation, your model is looking like the original. [clap]
Please provide us some data, if available.
What is the total weight? How much lead you have put into the nose and with what CG you will do the first flight?
I have calculated the CG for my Jastrzab and will start with 131mm from the profile nose at the root. I know that your wing is a little bit deeper than my one and that I have 20mm more distance between wing and tail.
I have used the program for the calculation you can find in the last post of my Jastrzab build thread. If you are interested, I can send you the input file of my calculation for this program.
Good luck for the maiden.
MessagePosté le: 26/05/2013 11:48    Sujet du message: Répondre en citant
Salut Thomas !
Bravo, il est vraiment superbe !
[clap] [clap] [clap] [clap] [clap] [clap]
[bave] [bave] [bave] [bave] [bave] [bave]
Il faudra que j'essaye le marqueur pour les petits marquages. A la peinture, j'ai du mal à avoir quelque chose de net. Tu en passes plusieurs couches ?
Thomas G.
Âge: 71 Poissons
MessagePosté le: 26/05/2013 11:52    Sujet du message: Répondre en citant
Hi Christian!!
Thank you for the compliments. Embarassed
I have put about 2kg lead into the nose, my model weighs now 11kg with CG about 100mm and ……. that is THE question!!!
I have calculated CG with PREDIM:
…as well as with SCHWERPUNKT:
I have got the difference 15-20 mm. I think, I’ll begin with 70-75mm. [humm]
Thomas G.
Thomas G.
Âge: 71 Poissons
MessagePosté le: 26/05/2013 12:03    Sujet du message: Répondre en citant
Salut Frédéric!
Pour le rouge, j’ai passé deux fois avec un intervalle de 5min. Avec le noir – une fois suffit.
Essentiel, c’est d’avoir un feutre avec la pointe en feutrine et non en fibre !!
[non]
Thomas G.
MessagePosté le: 26/05/2013 12:51    Sujet du message: Répondre en citant
Bonjour Thomas,
Il ne neige plus dans les Vosges, tu as pu sortir le planeur pour la peinture ! Il est magnifique!
Je suis ta construction de près. L'astuce des feutres est à retenir pour de petites inscriptions ou logos, le résultat semble nickel .
On arrive au même poids à peu près pour des envergures voisines, j'espère que l'on pourra faire un vol de patrouille Jasztrab/Laister/Habicht si les conditions le permettent ! Ce serait chouette. Je te téléphone tantôt Marc bises à ta mouette.. Wink
PS : tu as fini de masquer les rayons de soleil? Il n'y en a déjà pas beaucoup !! Laughing
Christian_B
Âge: 73 Capricorne
MessagePosté le: 26/05/2013 17:05    Sujet du message: Répondre en citant
Thomas,
I've calculated my Jastrzab again and have done the same calculation also for your's. I made a mistake with my first calculation and have found this now. Your calculation is correct I'm sure now.
With the above mentioned program I'm coming to 74mm for my Jastrzab (with 10% stability beween CG and NP). For your Jastrzab with some other dimensions I'm getting a range of 43.6mm (16% stability) and 74.9mm (8% stability). I would recommend to start with 70mm with your Jastrzab.
Thomas G.
Âge: 71 Poissons
MessagePosté le: 09/06/2013 22:31    Sujet du message: Répondre en citant
Jastrzab a fait son premier vol !!!
Sur le terrain du club CARMA à Bollenberg, grâce à la courtoisie de ses membres, j’ai pu mettre Jastrzab pour la première fois dans son élément.
Il s’est avéré, que :
-les ailes du planeur étaient parfaitement symétriques (peut être même sans aucun vrillage ?)
-calage ailes/stab env.0.8°est correct
-le centrage à 70mm est très neutre
Dans l’lagunage de nos revues préférées on dit : aucun trim n’était pas nécessaire.
Les aérofreins sont d’inefficacité redoutable (j’était prévenu) – il faut trouver une solution p.ex. mixage avec les ailerons ?
Et pour finir, un petit film avec l’atterrissage presque raté !!!
https://www.youtube.com/watch?v=QHjHGgBSECU&hd=1
Merci à Norbert pour le remorquage et à Dominique pour les photos !!!!!
Thomas G.
Christian_B
Âge: 73 Capricorne
MessagePosté le: 09/06/2013 22:46    Sujet du message: Répondre en citant
Congratulation Thomas!!!
Have seen the video and the flight looks good too.
Yes, landing with these brakes is not easy. Hope that it will be better with my two ailerons per wing half. Will have an additional Butterfly of the ailerons.
What is the final weight of your Jastrzab now with the CG at 70mm?
MessagePosté le: 10/06/2013 06:33    Sujet du message: Répondre en citant
Bravo pour ce premier vol [clap] tu trouves pas qu'après on dort mieux Laughing
Erix
MessagePosté le: 10/06/2013 08:40    Sujet du message: Répondre en citant
Ahoj Thomas,
Gratuluji k prvnímu letu. Sledoval jsem stavbu, krásná povrchová úprava.
Erix
MessagePosté le: 10/06/2013 09:20    Sujet du message: Répondre en citant
Effectivement, comme tu me le racontais hier, il vole vite et pousse bien à l'atterissage..Si tu relèves les ailerons, tu vas accroître le taux de chute mais sans réduire la vitesse à mon avis..A part faire des approches longues et plates...J'ai le même problème avec le Laister mais j'arrive à le ralentir...
En tout cas, félicitations pour ce premier vol qui récompense le temps passé à l'atelier Wink [clap] [clap] [clap]
MessagePosté le: 10/06/2013 10:45    Sujet du message: Répondre en citant
Salut Thomas !
Un grand bravo pour ce premier vol !
Très belle construction ! Je te souhaite de nombreux vols avec ton nouveau planeur !
Âge: 58 Verseau
MessagePosté le: 10/06/2013 10:53    Sujet du message: Répondre en citant
Salut Thomas,
congratulation for the maiden flight [clap] [clap] [clap] [clap]
Best Regards Olli
Nicolas M
Âge: 44 Taureau
MessagePosté le: 10/06/2013 16:08    Sujet du message: Répondre en citant
Magnifique thomas, quel beau vol et que dire de la plaine alsacienne? Quel beau jardin.
Nicolas
Profil NM retro, Classic et Spatz téléchargeables sur http://kipecoul.e-monsite.com/
MessagePosté le: 10/06/2013 22:33    Sujet du message: Répondre en citant
[clap] [clap] [clap] Thomas
Âge: 60 Vierge
MessagePosté le: 10/06/2013 23:09    Sujet du message: Répondre en citant
Bravo pour ce premier vol! [clap] [clap] [clap]
Jazstrab dans son élément et la forêt noire en arrière plan, belle photo!
A+,
1, 2, 3, 4, 5, 6, 7
Page 7 sur 7
