Nikolay Lebedev Stagiaire Posteur
Posté le: 01/07/2014 06:37 Sujet du message: |
Great Job, nice wood work ,Nikolay ![[clap]](images/smiles/Clap.gif) |
Posté le: 01/07/2014 06:57 Sujet du message: |
Hi Nikolay, congratulation, beautiful work, all these détails are for me the most pleasant, especially the spoked wheels. I don't see on the photos, how you made the rims? like me, in steel? or in brass?
Posté le: 01/07/2014 07:40 Sujet du message: |
Vincent,
I wanted to place the photos, but I struggled with the requirements to reduce photos to 100 kb and 600x600. Why not to make it automatically in your site:-).
Nikolay
 Nikolay Lebedev
Von hier bis unendlich! |
Posté le: 01/07/2014 07:47 Sujet du message: |
I could have the system with GD library but the original big file will be hosted on the server and take space disk, so I prefere that everyone resize himself his photos, it's easy and quickly
Posté le: 01/07/2014 13:04 Sujet du message: |
Vincent,
Some photos attached below. The wheels I did by the same method as you did, but I did not use hard-soldering because hard-solder temperature soften the spokes. But if we use a soft-soldering the original strength of the spokes remain the same as no effect of high temperature.
Actually to design and construct this model for me was a big challenge but the major job is done and I have to cover the model only.
I will post the pictures of covering process later, say end of July as now I am going to vacation, have some rest.
To be continued
 Nikolay Lebedev
Posté le: 09/07/2014 22:05 Sujet du message: |
Hi Nicolay,
It's really wonderful !
Posté le: 09/07/2014 23:06 Sujet du message: |
Very nice build. Original Sailplane.
Walter L. Maniaco Posteur
Posté le: 11/07/2014 19:18 Sujet du message: |
Hi Nikolay,
it is a really impressing glider! So many details like fittings, wires and the wheels.
I am waiting for the - of course positive - informations about the first flight.
Best regards
Walter |
Posté le: 31/07/2014 12:50 Sujet du message: |
Gents,
So, I completed the glider. Everything is done. The flying weight is around 4800 gr. Charged wing area 46 gr/sq dc. Wing span 3 meters.
Some weight left for balance, but it is almost 30% of the cord (365 mm).
Soon I will try to launch the glider by bungee start. I am afraid to launch it, I spent around one year to build it, so if it crashes, it will be a sad day for me.
In any case I will try to launch it.
P.S. It is my first experience to use Diacov tissue, it is very good and light for application tissue with good adhesion and shrinkage properties.
 Nikolay Lebedev
Posté le: 31/07/2014 13:08 Sujet du message: |
Congratulation Niikolay, the covering is clean
would you aging the Diacov with wood tint?
Posté le: 29/12/2015 22:46 Sujet du message: |
Hello Nikolay. Congratulations for this beautiful construction.
Your Avf-10 flew? ![[humm]](images/smiles/humm.gif)
Greg Accro Posteur
Posté le: 29/12/2015 23:19 Sujet du message: |
Yes, really nice work, and y wish you many nice flyghts ![[clap]](images/smiles/Clap.gif)
 Le vent se lève ..... |
bocorvin Maniaco Posteur
Posté le: 29/12/2015 23:46 Sujet du message: |
You are doing a great job!
I surely like the detailing.
Vincent |
