Nemere scale 1/6
Âge: 63 Capricorne
MessagePosté le: 25/01/2016 01:06    Sujet du message: Répondre en citant
Wow, so marvelous again. Lots of details so nice on this scale. Congratulations. [amen] [amen] [amen]
Âge: 80 Vierge
MessagePosté le: 30/03/2016 20:42    Sujet du message: Répondre en citant
Thank you all for the compliments!
All that was left to be done was the pilot and some interior details.
After a lot of hesitation I started with the head making in super sculpey, thanks to this forum! I found it not very easy to work with (its a bit sticky) I wanted tomake a pilot resembling Lajos Rotter.
After a lot of sweating this was the result...
It was heated in the oven (a bit to hot). I was to lazy to replicate it, so I drilled the head out to keep the weight down.
and accidentally drilled trough it. So I had to repair its scull .
I made the figure of balsa. The knee and elbow joints of copper (electrical wire) glued in the balsa limbs with cyano, the shoulder and hip from elastical cord.
(The protruding iron wire loop is just to pull the elastical cord through the balsa)
For his hair I used plumbers hemp (I guessed Lajos had black hair) glued on with PVA coloured with black acrylic paint
In the meantime Jenny had painted the face
I had asked my sister, Hans, to make his clothing. She started to make a pattern
and then the pants, shirt (with very small buttons!)
All the clothing has velcro on the rear.
Yes, the head is a bit big.
I also made a pair of sunglasses out of a pair old polaroid sunglasses.
and 0.45mm hard brass wire from Alan Gibson.
His "boots" is just his balsa feet, painted with cellulose with porienfuller, black acrylics and porienfuller again, well polished Very Happy .
I could not easily find a suitable harness so I just made it; the buckles from tinned 0.7 mm hardbrass and some scrap
it is secured with a 0.3mm clip, through a 0.5mm hole im the central (2mm) pin. It is attached with fake hexagonal bolts behind his shoulders.
In the cockpit itself I made the uncoupler handle on the left
The wooden round knobs came from an art shop. On the right side I made a holder for rhe aerial map.
Suddenly it seems finished! All the electronics work, cg is OK. She is a bit heavy, 2800gr.
Now its waiting for good weather, so we will fly it for the first time .
Some shots outside,
To be continued.
philippe44
MessagePosté le: 30/03/2016 20:46    Sujet du message: Répondre en citant
[amen]
MessagePosté le: 30/03/2016 20:50    Sujet du message: Répondre en citant
very very nice job !!
you have chance to have a lot of place in the nose to place all radio and details Wink
Greg
Âge: 84 Taureau
MessagePosté le: 30/03/2016 21:46    Sujet du message: Répondre en citant
Very Happy Stop, I can't more my eyes was putting outside!
Le vent se lève .....
MessagePosté le: 30/03/2016 22:32    Sujet du message: Répondre en citant
[clap] [clap] [clap] [clap]
MessagePosté le: 30/03/2016 22:41    Sujet du message: Répondre en citant
[clap] [clap] Superbe, et bons vols.
Âge: 63 Capricorne
MessagePosté le: 30/03/2016 22:44    Sujet du message: Répondre en citant
So marvelous details. Great great works [bave] [clap] [clap] [clap]
MessagePosté le: 31/03/2016 05:53    Sujet du message: Répondre en citant
Congratulation Vincent, amazing work on the clothes [clap] your pilot "hand made" has a Spirit, not like those from shop Wink [clap]
stéphane monot
MessagePosté le: 31/03/2016 07:16    Sujet du message: Répondre en citant
Hello,
[amen] [amen] [amen] [amen] [amen]
Stéphane
Âge: 80 Vierge
MessagePosté le: 31/03/2016 08:31    Sujet du message: Répondre en citant
Merci a tous, pour tous les compliments! Very Happy
My sister will be very pleased too,.
With a bit of luck it will fly on sunday, I'll keep you informed.
Âge: 72 Vierge
MessagePosté le: 31/03/2016 09:17    Sujet du message: Répondre en citant
nickel [clap] [amen] [good]
Âge: 72 Sagittaire
MessagePosté le: 31/03/2016 09:36    Sujet du message: Répondre en citant
Hello,
What can I said ? nothing more, It is a superb work.
And the pilot has not only a spirit, he has a soul.....
Great job.
LEROY
Âge: 74 Lion
MessagePosté le: 31/03/2016 10:30    Sujet du message: Répondre en citant
It is splendid, your pilot is a prowess [clap] [clap] [clap]
Michel.L
RichardP
Âge: 77 Cancer
MessagePosté le: 31/03/2016 16:21    Sujet du message: Répondre en citant
waouh [good]
Âge: 88 Taureau
MessagePosté le: 31/03/2016 16:51    Sujet du message: Répondre en citant
Beautiful work! Congratulations and best wishes for the maiden flight!
Âge: 54 Gémeau
MessagePosté le: 31/03/2016 16:59    Sujet du message: Répondre en citant
Hi Vincent,
It's awesome, congratulations [amen] [amen] [amen]
Not that heavy 2.8 kg, rather perfect Wink
Âge: 80 Vierge
MessagePosté le: 10/04/2016 22:19    Sujet du message: Répondre en citant
Merci a tous pour les commentaires joli!
Sorry I did not reply sooner but I was a bit nervous for the first flight! A lot of people said things as : "how dare you to fly with that thing you put some much time in".
Last week we had reasonable weather so we flew it, all went well, the photo's are OK, but the video didn't work out the way we wanted it.
The pilot is preparing for the first flight, sweating hands maybe?
I like to try a manual start first, put some tape on the fuselage for grip, the fuselage was wet.
Sjoerd giving it a mighty push! She flew without a hitch!
Preparing for the start, Claude is keeping the wings of the tarmac Very Happy
Rob is towing with his Piper, you can see the dolly just right of the white line.
His piper had plenty of power to clear the trees!
She flew beautiful Very Happy
The spoilers need a bit of trimming up.
She landed OK! Very Happy
The photo's were taken by Rob, Adri and Sjoerd.
Hopefully we can make some video's, I let you know.
Âge: 60 Taureau
MessagePosté le: 10/04/2016 23:09    Sujet du message: Répondre en citant
Congratulations [clap] [clap] [clap] !
Wonderful work, so splendid on the floor and splendid in the sky [amen] [amen] [amen] !
I wish you a lot of flights.
MessagePosté le: 11/04/2016 04:47    Sujet du message: Répondre en citant
Congratulation Vincent for this maiden flight [clap]
he's Claude Moinier on the photo?
stéphane monot
MessagePosté le: 11/04/2016 07:09    Sujet du message: Répondre en citant
Félicitations et bons vols [clap] [clap] [clap] [clap]
Stéphane
Âge: 72 Vierge
MessagePosté le: 11/04/2016 08:41    Sujet du message: Répondre en citant
bravo et nombreux vols avec [clap] [clap]
MessagePosté le: 11/04/2016 09:08    Sujet du message: Répondre en citant
Âge: 88 Taureau
MessagePosté le: 11/04/2016 10:37    Sujet du message: Répondre en citant
Beautiful in flight! Congratulations
LEROY
Âge: 74 Lion
MessagePosté le: 11/04/2016 11:45    Sujet du message: Répondre en citant
Beautiful in flight !! [clap] [clap] [clap]
Michel.L
Âge: 80 Vierge
MessagePosté le: 11/04/2016 13:40    Sujet du message: Répondre en citant
Merci Serge, Vincent, Stéphane, Dominique, Christian, Pierre et Michel pour les compliments! Very Happy
Vincent, you are right, it's Claude Moinier.
MessagePosté le: 11/04/2016 14:10    Sujet du message: Répondre en citant
Lovely sailplane, not large but ideal for many flights all year long on aerotowing or slope ! [clap] [clap]
MessagePosté le: 11/04/2016 15:08    Sujet du message: Répondre en citant
MARVELOUS first flight !! [clap]
a very nice building for a long time to fly now !
Next to see a vidéo so ?
Âge: 63 Capricorne
MessagePosté le: 11/04/2016 20:38    Sujet du message: Répondre en citant
Congratulations for this first flight. [clap] [clap]
MessagePosté le: 11/04/2016 22:32    Sujet du message: Répondre en citant
[clap] [clap] [clap] Vincent .
Page 3 sur 4
