Fokker FG-2 - Congrès 2017 Vauville
MessagePosté le: 16/04/2017 15:00    Sujet du message: Répondre en citant
Entschuldige Vincent das ich mich erst heute melde:
[amen] [amen] Dein erster F-Schlepp ist super geworden :
Herzlichen Glückwunsch [amen] [amen]
Weiterhin tolle Flüge mit schönen weichen Landungen [clap] [clap]
Liebe Grüße Johannes
MessagePosté le: 16/04/2017 19:16    Sujet du message: Répondre en citant
[clap] [clap] [clap] belle machine
Signé les copains
Âge: 79 Vierge
MessagePosté le: 17/04/2017 10:17    Sujet du message: Répondre en citant
Danke Johannes, ja ich war ganz erleichtert das der FG gut geflogen hat Very Happy
et merci Pierre, le FG c'est certainement une machine!
Je continue en Anglais,
To start with, it was an relief and at the same time very rewarding to see th FG flying, she is so translucent, a bit archaic, we enjoyed it very, very much!!
After these first flights it was obvious that the cg was too for forward. Somewhere the fact was in my mind that the main girder was on 30% and I put the cg there. Later I discovered that the girder was on 25%, so I had to take out some lead. I figured out that about 220 grams less was sufficient.
No easy acces, the camera is much smaller than my head!
Two holes in the diacov to take the bolts out
Some wrenching because the lead was glued with epoxy
and with tweezers put the nuts back
Th cg was now at 30%, hopefully that is right, at least I know how to get out more!
There was another thing that worried me, the wiring or rigging of the wing warping. I made a sketch to clarify things
as you can see there are two ( I came up with the names, maybe ther are better names for those wires) "control wires" ataching the servo arm with the upper wings, and one "connecting wire" between the lower wings via a pulley inthe center just under the upper wing. If there is a failure of one of the control wires, the plane is uncontrolable, its only possible to roll to one side and not back. That was a worrying thought! When testing stationary sometimes the quicklink on the servo arm snapped out and after the handlaunches there also unsnapped other quicklinks. I didn't trust the quicklinks 100%. There are other quicklinks with locking plates
(top on the picture) put the locking plates are so tiny, they will get lost, I am afraid. I made a spring of 0.6 steel wire, around a 4mm drill and snipped off pieces of a couple of windings, which you can slide over the quicklink (bottom) It looks reassuring, hopefully they do there job.
I could not use this on the servo arm, because of the full throw I need there. I modified the quicklinks into more permanent linking
The bushes are long enough to give free rotation when the M 2 nuts are fastened. The metal strips are ment to give a better load distribution on the plastic of the servo arm.
I use these locking rings on some important quicklinks of the other rigging, so I get a bit more trust in all those wires!
One advantage of the wiring and floppy wings is the following thing; by adjusting (shorter) the "connecting wire"it is possible to introduce a smaller angle of incidence at the tip, to get better stall charasterics.
To be continued,
Vincent.
Mad Doc
Âge: 49 Scorpion
MessagePosté le: 20/04/2017 12:48    Sujet du message: Répondre en citant
Ich hab auch lange nicht reingeschaut, staune um so mehr!! Toll! Super Erstflug-Video!!!!
Holland ist natürlich ein sehr toller Ort um zu schleppen, Ihr habt dort so viel Platz und gerade Flächen... und nebenan direkt eine Wasserflug-Startbahn...
Herrlich!
Liebe grüße,
Âge: 79 Vierge
MessagePosté le: 20/04/2017 15:20    Sujet du message: Répondre en citant
Hallo Christian,
Ja, die Erstflug war schon!! Doch immer ein bisschen "No guts no glory".
Ich hatte immer geglaubt das in Deutchland mehr Platz um zu fliegen wahre, im Holland ist das sehr schwierig irgendwo platz zu finden, so wir sind ganz froh mit diese Stelle. In eine woche hatten sie die Graben gemacht und dan gab es Wasser! Und mit Wasser ist das genau dasselbe wie mit Baume, die Modellen ziehen dahin Sad .
Liebe grüße,
MessagePosté le: 23/04/2017 21:43    Sujet du message: Répondre en citant
Salut Vincent,
Un grand bravo ! Il est superbe ton biplan, la silhouette et la transparence waouwww, magnifique ! [amen] [amen] [amen]
Âge: 79 Vierge
MessagePosté le: 24/04/2017 13:44    Sujet du message: Répondre en citant
Salut Lolo,
Merci beaucoup !Very Happy Very Happy
I am also very pleased with the transparancy of the wings, the 140+ "nervures aux baquettes" had their effect!
Âge: 79 Vierge
MessagePosté le: 07/05/2017 18:50    Sujet du message: Répondre en citant
Bonjour a tous,
I did some small things, to make the quicklinks less visible I blackened them chemically with Bernax 540 of which I happened to have some.
rinsed them with water.
Then I discovered a problem; on which spot could someone hold the plane when the catapult (sandow) was under tension?
I think the rudders are to weak, the attachment for the horizontal stabilizer is also a bit weak, besides there is no room for one hand. Rigging wires all over the place!
So I made a device, or better said a contraption to hold the glider in place with the catapult under tension, with a release hook.
I used a modified standard release hook connected with a 8mm stainless steel tube attached to a wooden handlebar. A 1mm stainless steel operating wire with a rope loop as a trigger.
On the plane I made also a demountable loop, attached to 0.6 mm steel wire, which was connected to one of the wing struts.
Here Sjoerd demonstrates how it should work (I tested it at home with 15 KG tension and the plane stayed horizontal too)
Today Rob towed the FG 2 again and it performed well.
The CG looks OK, the elevator is just a degree or 2 up, the plane was really flying!
MessagePosté le: 07/05/2017 19:26    Sujet du message: Répondre en citant
Hi Vincent,
spitze wie Du solche Probleme löst -
super Idee [clap] [clap]
MessagePosté le: 07/05/2017 19:27    Sujet du message: Répondre en citant
hello Vincent,
Very interesting your system of trigger of dropping for the plane difficult to block on hands… !! [clap]
Âge: 79 Vierge
MessagePosté le: 07/05/2017 21:54    Sujet du message: Répondre en citant
Hello Johannes und Sebastian,
Thanks! Hopefully this thing works properly at Vauville!
fabplane56
Âge: 50 Balance
MessagePosté le: 04/07/2017 13:42    Sujet du message: Répondre en citant
beautifull model , and the work on it is simply awesome ! i wish i had the skill to make a such model [amen] stickers voiture
Âge: 79 Vierge
MessagePosté le: 04/07/2017 16:07    Sujet du message: Répondre en citant
Thanks a lot for your comment!
About the skills, its mostly a matter of practice...
MessagePosté le: 29/07/2017 23:04    Sujet du message: Répondre en citant
Je ne me lasse pas de regarder ta vidéo , merci pour les images elles trouveront leur place sur la vidéo Very Happy
Quel bonheur d'avoir vu voler plusieurs fois ce Fokker sur une des plus belle pente de France [baaave] ,
Âge: 72 Vierge
MessagePosté le: 30/07/2017 08:27    Sujet du message: Répondre en citant
alors la un très grand bravo c'est du grand art [clap] [clap]
Âge: 79 Vierge
MessagePosté le: 30/07/2017 14:39    Sujet du message: Répondre en citant
Merci Christian pour les photos. Nous sommes encore en France, j' ai seulement mon telepbone et je ne peux pas voire le video Sad
Vincent.
Âge: 79 Vierge
MessagePosté le: 30/09/2017 12:20    Sujet du message: Répondre en citant
Hello everyone,
Some time ago we went with the FG2 to the Fokkerfair, a yearly event organised (if I am correct) by the Historical Fokker foundation.
Claude (who gives always a tremendous support) and me are building up the FG2, all those small clips Confused. Even the local tv came along
The plane right under construction is Robs Fokker FXX, the only Fokker commercial plane with retractable landing gear. Rob is also the pilot of the Piper, the plane that towed the FG2.
From left to right; the FG, Robs Fokker FXX and Fokker FVIIb/3m, Southern Cross and we are sitting in front; me, Claude, Rob and Adri (from the anemometre)
Last weekend we flew the FG2 again, it went allright, but flying with it on a level field is not a real joy. The steering is OK, but its coming down very fast, there are no (extra) brakes and I don't dare to side slip it, so its difficult (for me) to land. The skid is also very vulnerable with landing. It has already been replaced twice and there was some minor damage inside the fuselage.
In Holland are no suitable hills to fly it, so I think I store it till next Retroplane or maybe another meeting.
Vincent.
MessagePosté le: 30/09/2017 13:58    Sujet du message: Répondre en citant
Hallo Vincent,
Glückwunsch zu dem tollen Fokkertreffen [clap]
Das Segelflugzeug macht sich gut unter den Motorfliegern Very Happy
Ja so ein Hang wie in Vauville ist eimalig da fliegt einfach alles.
Seid Retroplane ist das Stehaufchen schon über 20 mal geflogen
un dauch noch alles ganz [oouf] ich hoffe es bleibt so auch besonders
bei Deiner FG2.
Viel Spaß auch weiterhin
Fotor
Âge: 50 Gémeau
MessagePosté le: 26/03/2018 16:39    Sujet du message: Répondre en citant
Last weekend we had an aerotow meeting in the Netherlands. Vincent brought his Fokker and made some flights. It's still a magnificent sight to see this retro model in the air. The model got a lot of attention.
Some photos:
HD http://www.esveldt.demon.nl/Model/Kampen18-35.jpg
HD http://www.esveldt.demon.nl/Model/Kampen18-36.jpg
HD http://www.esveldt.demon.nl/Model/Kampen18-37.jpg
HD http://www.esveldt.demon.nl/Model/Kampen18-68.jpg
HD http://www.esveldt.demon.nl/Model/Kampen18-69.jpg
HD http://www.esveldt.demon.nl/Model/Kampen18-77.jpg
HD http://www.esveldt.demon.nl/Model/Kampen18-72.jpg
Nouveau messagePosté le: 26/03/2018 17:01    Sujet du message: Répondre en citant
[clap] [clap] [clap] [clap]
Nouveau messagePosté le: 26/03/2018 17:03    Sujet du message: Répondre en citant
[good] Es ist schon was seltenes so einen
schönen Doppeldeckersegler zu sehen Very Happy
LGJ
Nouveau messagePosté le: 26/03/2018 17:08    Sujet du message: Répondre en citant
[clap] [clap] [good]
LEROY
Âge: 73 Lion
Nouveau messagePosté le: 26/03/2018 17:42    Sujet du message: Répondre en citant
Splendide [clap] [clap] [clap] [clap] !!!!!!
Michel.L [vol]
Âge: 79 Vierge
Nouveau messagePosté le: 26/03/2018 19:26    Sujet du message: Répondre en citant
Thanks a lot Raymond [clap] [clap] [clap]. Its so nice I can focus on the flying and in the meantime you just made all those nice shots!
It was indeed a inspiring meeting and luckily we had very good weather Very Happy
mAtzi
Âge: 65 Taureau
Nouveau messagePosté le: 28/03/2018 12:25    Sujet du message: Répondre en citant
Gratulation! [clap]
Âge: 79 Vierge
Nouveau messagePosté le: 28/03/2018 18:26    Sujet du message: Répondre en citant
Thanks for all those nice comments!
While watching these photo's for another time, I suddenly realised that you can see the wingwarping in action. Normally you can't see it, but on the third photo (from the top) where the FG 2 is on close approach its clear to see, the left wings are giving '"up" and the right wings are "down". (luckily I made the right correction Very Happy )
Nouveau messagePosté le: 29/03/2018 10:06    Sujet du message: Répondre en citant
Cool great success Vincent [clap]
Signé les copains
Flattersaus
Âge: 58 Scorpion
Nouveau messagePosté le: 28/06/2020 18:25    Sujet du message: Répondre en citant
Guten Tag aus Deutschland,
ich möchte ein Artikel aus der Berliner Illustrirten Zeitung als Dokument ergänzen. Viel Spass
 Taille du fichier:  329.31 Ko
 Vu:  815 fois
 Taille du fichier:  337.14 Ko
 Vu:  783 fois
 Taille du fichier:  484.09 Ko
 Vu:  780 fois
Âge: 79 Vierge
Nouveau messagePosté le: 30/06/2020 16:13    Sujet du message: Répondre en citant
Hello Ralph,
Danke fur das Artikel aus der Berliner Illustrirten Zeitung!
Das hat mit viel Spass gegeben und Ich sende das gleich nach einige Leuten in Nederland die mit mit die documentation geholfen hatten, klasse!
Leider fliegt der FG-2 diese sommer nicht am Waku, hoffentlich nachstes Jahr.
LG
Vincent (DB)
Âge: 79 Vierge
Nouveau messagePosté le: 25/02/2021 13:20    Sujet du message: Répondre en citant
In the (renewed) RCSD is an article about the FG-2.
https://medium.com/rc-soaring-digest
Vincent(DB)
Page 7 sur 8
