GustavoSperotto Stagiaire Posteur
Posté le: 02/11/2018 19:13 Sujet du message: Doppelraab in Brasil |
Bonjour everyone,
Sorry about the language.
My name is Gustavo, I'm writing from south Brasil.
Enjoy a lot the theme old planeurs.
I'm planning to make a Doppelraab.
For instance, still buying the material. I can't promisse a quik construction.
I will post pictures. |
Posté le: 02/11/2018 20:13 Sujet du message: |
Hi Gustavo, welcome to the forum
We are waiting your building ![[scie]](images/smiles/scie.gif)
Posté le: 18/11/2018 19:09 Sujet du message: First questions |
Vincent and friends,
Still waiting for some woods, but need a help:
I have 2 prints: one is the plann itself and the other is probably the draws for the laser cut, which shows the "Q" piece in two segments.
Maybe it´s because the laser cut machines can´t cut big pieces?
I will not use laser cut, so is it better to use the Q piece in one single piece, confirm?
Other question is about the need (or not) to build the air brakes (in the wings). They are not in the plann, and I read that Vincent didn´t do it in his Doppel. But if you are doing your model now, will you buid them? If so, where can I find a good scketch? |
Posté le: 21/11/2018 01:46 Sujet du message: |
I'm having trouble to take pictures with max 600x600 pixels. The lowest resolution of my camera is 640x480 pixels, with 95Kb.
Any tips? |
Posté le: 21/11/2018 02:16 Sujet du message: |
Dear Gustavo,
You have to change the weight of the pic with a software ( usualy , they propose a coneversion for Web ) as Microsoft office picture manager. and then upload on the forum.
Posté le: 23/11/2018 00:59 Sujet du message: |
Let the fun begins
Posté le: 23/11/2018 01:29 Sujet du message: |
| I started to cut the plywood parts with a blade, but it's too heavy for my elbow. I will borrow a jigsaw tool from a friend of mine. Regret to not use the laser cut... at least for the ply parts. |
Posté le: 27/11/2018 23:39 Sujet du message: |
Vincent, you were right. The air brakes draws are on the plan. Perhaps I was without glasses...
Pat, thanks for the tips with the pictures sizing.
Until now, I have cutted all CTP parts of the fuselage, but 3 of them I will have to repeat cause they broked. Not easy to cut some parts. |
Posté le: 05/12/2018 00:02 Sujet du message: |
A stubbord N1 requires a high skill to shape.
Next will be N2. |
Posté le: 29/12/2018 21:44 Sujet du message: |
Those reindeer went out for a strike....mmmmmmm..... having some ideas for the next Christmas |
