Slingsby Gull scale 1/4
1, 2, 3, 4, 5, 6 Suivante
Âge: 63 Scorpion
MessagePosté le: 18/09/2019 20:16    Sujet du message: Répondre en citant
[clap] nice job, very technical ! i like it Very Happy
Âge: 80 Vierge
MessagePosté le: 12/10/2019 08:54    Sujet du message: Répondre en citant
Bonjour a tous,
I went on with the ribs, finally the very thin battens (1 X 1mm) had arrived and I drawed the pattern for them on the ribs with pencil
The battens are cut off after glueing with a small wire cutter, and sanded.
Now I could built the wing itself
I like the curve in the wing!
to be continued,
Âge: 80 Vierge
MessagePosté le: 26/10/2019 11:07    Sujet du message: Répondre en citant
Bonjour a tous,
After gluing in all the battens and vertical webs I went on with the hinges. I used the method of Vincent Besancon (sorry I don't have the French correction Sad ) and I pre cut the ribs
so I could glue the hinges in place before cutting of the aileron. Next I tried to figure out the pulleys of the pull pull wires
and getting the angles correct. The rudderhorns on the aileron have the same throw as the on the servo. I had to create a lot of space for the wires in the ribs at the root, even I had to reinforce one rib.
planning the pull pull wires
The actuation of the spoiler came quite close to the pull pull wires of the ailerons.
The servo arm is in its most extended position when the spoiler is closed, so there is less chance of burning the servo....
Laminated tip
and the trailing edge is built up of 0.8 mm ply bottom and top, balsa in between. I laminated the balsa also in the curve of the trailing edge
I guess there is less figuring out with the other wing Very Happy
Âge: 60 Taureau
MessagePosté le: 26/10/2019 14:26    Sujet du message: Répondre en citant
Perfect job as usual [amen] [amen] !
Âge: 58 Verseau
MessagePosté le: 26/10/2019 15:47    Sujet du message: Répondre en citant
Hi Vincent,
very nice build [clap] [clap]
Best Regards Olli
Âge: 80 Vierge
MessagePosté le: 26/10/2019 22:33    Sujet du message: Répondre en citant
Thanks Sed and Olli for your nice commets Very Happy Very Happy !
Mad Doc
Âge: 50 Scorpion
MessagePosté le: 31/10/2019 15:30    Sujet du message: Répondre en citant
Hello Vincent!!!
What a beautiful model, and what a nice work!
I´m sure it will look just nice in the air!
Greetings,
Âge: 80 Vierge
MessagePosté le: 01/11/2019 12:32    Sujet du message: Répondre en citant
Hello Chtistian, thanks for your nice comment Very Happy .
In the meantime I went on with the other wing and that went indeed a lot faster! So yesterday I put it all together in the sunshine, its now raining Sad First in the attic (It just fits)
And outside
To be continued,
Vincent.
Âge: 80 Verseau
MessagePosté le: 01/11/2019 12:38    Sujet du message: Répondre en citant
Prachtig! Een echte kunstwerk.
[amen] [amen] [amen]
Âge: 54 Gémeau
MessagePosté le: 01/11/2019 13:30    Sujet du message: Répondre en citant
Wow, magnificent job Vincent !!!
Friendly
Âge: 80 Vierge
MessagePosté le: 01/11/2019 14:31    Sujet du message: Répondre en citant
Merci Harold et Lolo,
Thanks for your nice comments!
Hopefully it will fly nice, Each wing is 650gr at this moment
To be continued,
jean-jacques stannard
Âge: 73 Poissons
MessagePosté le: 01/11/2019 15:19    Sujet du message: slingsby gull Répondre en citant
Very Happy Dreaming build !!!! [clap] [clap] [clap]
MessagePosté le: 01/11/2019 19:46    Sujet du message: Répondre en citant
Hallo Vincent,
Die Holzkonstruktion sieht wunderschön aus [amen]
viel zu schade diese unter einem Gewebe zu verstecken Embarassed
Liebe Grüße
Âge: 58 Verseau
MessagePosté le: 01/11/2019 19:53    Sujet du message: Répondre en citant
Hi Johannes,
der Rumpf und der Nasenkasten werden aber
doch beplankt Wink
Nice Work Vincent [clap] [clap]
Best Regards Olli
Âge: 80 Vierge
MessagePosté le: 01/11/2019 20:26    Sujet du message: Répondre en citant
Thanks all for the encouraging comments Very Happy
First I have to finish the construction of the wings, then all the pull-pull wires for the controls, than the canopy mold and then all the bits of ply. It will take some time!
Die rumpf ist vollig beplankt, die Flugel nur die nase, hier noch ein photo von das vorbild.
Âge: 63 Scorpion
MessagePosté le: 01/11/2019 23:48    Sujet du message: Répondre en citant
Hello,
MARVELOUS [clap]
Superbe dentelle de bois !
Il doit être très léger ! tu l'a pesé en l'état ?
Âge: 80 Vierge
MessagePosté le: 02/11/2019 09:03    Sujet du message: Répondre en citant
Hello Sebastian,
Merci pour les comments Very Happy
In this state it weighs 2150 gram, I hope it will stay under 4000 gram when ready, (I hope...)
Âge: 80 Vierge
MessagePosté le: 07/11/2019 15:46    Sujet du message: Répondre en citant
Bonjour a tous,
Now I had to seperate the ailerons from the wings, the hinges were already glued in place
a small saw cut just opposite the hinge
(not the same rib)
A lot of sanding...
and to my great relief it fitted OK.
I wanted to build the round nose of the aileron from 0.8mm ply, so it should form a small ply "D "box to add torsion stiffness to the aileron.
Bending the ply with boiling water
drying
After some trials I made quite small panels (couldn't handle bigger ones Sad ) glued it with thick cyano at one side
and after hardening, to the other side
clamping it firmly, its not a big radius....
Made the apertures for the hinges with a Dremel (in fact a proxxon) and joined it with a wing
it is very stiff in torsion Very Happy
The trailing edge of the wing itself from a strip of ply itself still must be added, should give a small gap.
The pulleys are already waiting for the pull-pull cables....
Âge: 63 Scorpion
MessagePosté le: 07/11/2019 16:35    Sujet du message: Répondre en citant
Hello Vincent,
let's talk in english (i hope)
we are on the same job Laughing
dont you bend before the plywood on a metal tube ? it's more easy and keep the form to glue after without forcing !
another thing ; you should put a tube in front of the hinge pin for better rotation; that's what I do for a few grm of + Laughing
good continuation !
Âge: 80 Vierge
MessagePosté le: 07/11/2019 17:00    Sujet du message: Répondre en citant
Hello Sebastian,
Thanks for your pleasant comments Very Happy .
Well, I started with bending around a tube, but pouring boiling water over the ply, while at the same time the clamps (washing pegs Laughing ) bend the ply, suited me better. So the strips are pretty well prebend. I had problems to get the ply flush glued to the 3 X 3 stringers, that why I needed the big clamps .
Maybe it was easier to take a much wider strip and cut the surplus of after gluing. (But its already finished)
It feels very rigid and I just wrote down how I fixed it, certainly there are many (good) other ways to get a proper result Very Happy
Âge: 80 Vierge
MessagePosté le: 10/11/2019 20:08    Sujet du message: Répondre en citant
Bonjour a tous,
Actually I was a bit afraid that the pull-pull wires for the aileron actuation wouldn't work properly. I had to know if my planning worked! So I jigsawed ( Very Happy ) the rudderhorns from 1mm epoxy/glass sheet, covered them with 0.8 mm ply. From 0.6 mm steel I bended loops so I could connect (and disconnect) the pull-pull wires to the rudderhorns. Put the wires through all the holes in the ribs to the servo arm and back.
I had already soldered brass tubes to the pully unit as guidance for the steering cable of the outer rudderhorns of the aileron.
So I was very relieved it worked, I can now go further with the wings Very Happy
To be continued,
Âge: 58 Verseau
MessagePosté le: 11/11/2019 06:23    Sujet du message: Répondre en citant
Super Vincent [clap] [clap] [clap]
Âge: 54 Gémeau
MessagePosté le: 11/11/2019 09:55    Sujet du message: Répondre en citant
Hi Vincent,
Bravo !
It's superb ! [amen] [amen] [amen]
Friendly,
Âge: 77 Bélier
MessagePosté le: 16/11/2019 08:26    Sujet du message: Répondre en citant
Die Anlenkung des QR und alles andere - großartig [amen] [clap] [amen]
Manfred
Âge: 80 Vierge
MessagePosté le: 16/11/2019 11:59    Sujet du message: Répondre en citant
Thanks Olli, Lolo and Manfred for your encouraging comments!
I was indeed very relieved the ailerons worked OK!
I went on with the fastening of the wingjoiner tubes. I liked to reinforce this part with glass tape/epoxy and filler/epoxy. Slow hardening in this case.
I left a gap between the tubes and the spar
worked wet in wet
and cut of the surplus when its partially hardened
It always looks a bit messy, but I think its strong.
After this I went on with the canopy positive. Made from 6 layers 30mm balsa, sawed to fit in the fuselage
and then cutting. planing and sanding.
Its to big to get my fingers around it...... I used rubberbands, made from inner tyres of a moped Laughing
shaped the nose also a bit more.
Daniel Gmür
Âge: 63 Bélier
MessagePosté le: 20/11/2019 23:02    Sujet du message: Répondre en citant
Wow! Nice to see, in which way your fighting for a stable but a very very non heavy Weight construction [clap] Maybe less than 50 gr/dm2 at the end? Thermal bomb! Will watch your Progress and further (metal details) with Great pleasure. Daniel
Mad Doc
Âge: 50 Scorpion
MessagePosté le: 21/11/2019 12:36    Sujet du message: Répondre en citant
Hi Vincent!
I really like your idea to use one servo on the ailerons, but separate the heading by cables on two places. Great, i will place this in my mind for further projects!
Greetings from Wuppertal,
Âge: 80 Vierge
MessagePosté le: 21/11/2019 14:59    Sujet du message: Répondre en citant
Hello Daniel and Christian,
Thanks for your nice remarks Very Happy
I am glad to share the building problems and solutions on this forum Very Happy
Yes, I hope to get the weight below 4 kG, but I hope...
About the aileron actuation, it worried me if it should work.... The only thing I did, was making the lenghts af all the arms ( servo and both rudderhorns) exactly the same, in theory it must work and to my relief it did. I also learned a lot of all the wires of the Fokker FG 2.
http://www.retroplane.net/forum/viewtopic.php?t=4779&postdays=0&postorder=asc&start=90
The servo arm, lever, was critical, it must fit in the thickness of the wing, thats why I placed it at the root.
The beefing up of the wing joiners is because I want it to fly as a Gull with struts and also as a "cantilever Gull" without struts Very Happy
Regards and LG
Âge: 80 Vierge
MessagePosté le: 23/11/2019 16:37    Sujet du message: Répondre en citant
Bonjour a tous,
After sanding the canopy mold fit to the fuselage, I added extra material for the vacuum moulding
This mould was too big for my equipment, luckily a modelshop in the Netherlands does the job very well
it also fitted on the fuselage
I was a bit puzzled about the seat of the pilot, the drawing was also not very clear about it ( I thought Confused ). A couple of days ago I found the first photo of the Gull with the pilot in the cockpit.
I my mind the head of the pilot is mostly more or less flush with the rear of the canopy, but not on this picture. So I had to change quite a lot of things Shocked The servo's needed to go back quite a bit....
I put the servo for the tow release on the bottom
and the elevator and rudder on top
some figuring out.... But now there is space to put the pilot in correctly
Made the seat from a ply/balsa sandwich
to be continued
Âge: 80 Vierge
MessagePosté le: 28/11/2019 13:23    Sujet du message: Répondre en citant
Hello everyone,
I started to put the ply on the fuselage, Because I made the middle section of the wing separate, I had some problems to solve [argh]
Now I could glue in the central part and cover the top side.
check that all fits and is horizontal
glued in both top panels (these seams will be under the fairing)
a epoxy fillet to attach these panels firmly
Now I could do the topside of the tailboom. After making a panel fit, I put in two pins to put the panel at the proper place. Now I glue the panel with thick cyano only at the stringer
and after a minute I put on glue on the frames and other stringer and wrap the panel in place. To make the horizontal stabilizer fit to the fuselage, I had to make a balsa filler.
to be continued,
Page 2 sur 6
