Schweizer SGU 1-19 avec fuselage en tube
Âge: 79 Vierge
Nouveau messagePosté le: 02/04/2025 14:58    Sujet du message: Répondre en citant
Bonjour a tous
When the weather was not good for flying, I assembled the Schweizer in the clubhouse in the hope that someone had a idea for the colour scheme. Fortunately, that turned out to be the case and Rob sent me a nice proposal. I discussed it with Claude and looked with Adri at how that could be realized. Fortunately, Adri still had a large piece of matte red adhesive foil and I could cut out the red stripes. First made a template from paper transferred that to plywood, cut and sand it. Adri digicrafted the logo for the rudder surface and plotted that with the registration and black lines .
Claude had a very good idea about the registration; the N (because it was mostly used in the US), followed by our year of birth Very Happy
Claude's wife is going to make a nice shawl for the pilot, otherwise she will really get goose bumps.
Everything else works and it is ready for the first flight, always exciting. (Actually, most flights are exciting..)
Nouveau messagePosté le: 02/04/2025 15:24    Sujet du message: Répondre en citant
Super ! sobre mais très réaliste !
et cette transparence qui laisse voir toute la structure c'est vraiment très beau [clap]
Have a nice flight now !
Nouveau messagePosté le: 04/04/2025 08:13    Sujet du message: Répondre en citant
Hallo Vincent,
mal wieder: Ein traumhaftes Modell wieder erschaffen [amen] [amen]
Âge: 79 Vierge
Nouveau messagePosté le: 04/04/2025 11:38    Sujet du message: Répondre en citant
Hallo Sebastian
Merci Very Happy et oui les bandes rouges me plaise aussi!
Danke Very Happy , vielleicht fliegt er ahnlich wie die Grune Post!
Amicalement, LG,
Vincent (DB)
Âge: 79 Vierge
Nouveau messagePosté le: 13/05/2025 10:49    Sujet du message: Répondre en citant
Bonjour a tous,
The SGU 1-19 had made its first flight. The prototypical tow hook didn't work as it should, but it flew well, that was nice. Very Happy Very Happy
The landing was not nice, I didn't wont to fly over the people. The steel tube is really strong, luckily. A (too small) aileron servo was damaged. So I had to replace the hook and aileron servo's, that will take some time.
The link to the video,
https://youtu.be/c8T_13t1haI
Vincent (DB)
Nouveau messagePosté le: 14/05/2025 06:33    Sujet du message: Répondre en citant
Puh - das war ein spannender Erstflug, Vincent.
Aber schön das es gut gegangen ist Very Happy
Ich freue mich schon auf unser Wochenende [good]
Nouveau messagePosté le: 14/05/2025 11:28    Sujet du message: Répondre en citant
Bravo Vincent pour ce premier vol [clap]
Le crochet de largage du câble n'a pas fonctionné ? problème de servo ?
Âge: 79 Vierge
Nouveau messagePosté le: 14/05/2025 12:59    Sujet du message: Répondre en citant
Danke Johannes, und die SGU ist, wie sagt mann das, ziemlich stark Very Happy
Sebastian, I had some unreliabilty problems with my hook of the Nemere 330cm span, it was a miniature of the original one. So I change this coupling and the Nemere one for a piece of tube with a peg in it as in my Slingsby's
This hook never failed me and I hope the same for the future!
Vincent (DB)
Âge: 79 Vierge
Nouveau messagePosté le: 16/09/2025 10:16    Sujet du message: Répondre en citant
It took a while, but more flight(s) have been made.
To refresh what happened, the very first tow went up well, unfortunately the (scale) coupling did not disconnect properly resulting in a hard landing with the tow line still attached.
Because the ailerons have quite a bit of mass, an aileron servo broke.
At home I replaced the servos with larger ones and replaced the scale coupling with a tube with pin coupling.
That was quite a hassle because to build in. Unfortunately I don't have any pictures of that, busy with other things.
Recently, the SGU has made quite a few flights and turned out to fly well, a decent descent speed, a lot better than the Fokker FG-2.
On a tow meeting in Alkmaar, Sjaak (from EVA) took pictures, it shows well!
This link is to a YT video on which I put all the material I have, subtitles are in Dutch, sorry for that.
https://www.youtube.com/watch?v=znVIy4hqE3o
Vincent (DB)
Nouveau messagePosté le: 17/09/2025 12:02    Sujet du message: Répondre en citant
Hello Vincent,
nice flight [clap]
Ton crochet de remorquage n'est pas encore tout à fait au point Laughing mais en tous cas le vol est superbe !
Bons prochains vols à venir !!
Âge: 79 Vierge
Nouveau messagePosté le: 17/09/2025 12:17    Sujet du message: Répondre en citant
Bonjour Sebastian,
Thanks for your comment Very Happy
It is a bit confusing, the video is a combined one with all the footage I had. So the first flight is again in this video. I already made a new coupling which does its job OK Very Happy
It was quite a hassle to get it in [argh]
Vincent (DB)
Page 4 sur 4
