nobrega Stagiaire Posteur
Posté le: 23/09/2007 11:29 Sujet du message: Minimoa of 2,2m |
Hi.
I am making a Minimoa of 2,2 meters.
Here are some pictures of the fuselage plug.
I make a drawing of three view picture and make the plug. I am planning to make the fuselage on fiber glass and the wings of balsa wood.
Je suis en train de faire un Minimoa en 2.2m
Voici quelques photos du master du fuselage.
J'ai fais le master a partir d'un plan 3 vues. Je vais faire le fuselage en fibre et les ailes en structure
This is pictures is a KW-1 glider, a brasilian glider of 1960...
I like a lot of "Retroplanes"
Voici des photos du KW-1, un planeur Bresilien des années 1960.
J'aime bien les Retroplanes (planeurs rétro)
Edson Nóbrega |
Lothar Mentz Accro Posteur
Posté le: 23/09/2007 23:12 Sujet du message: |
Hi Nobrega,
Your pictures are looking great. I wished I would be as far as You with my projects.
I think a 2.2 m Minimoa is a great to handle sweet airplane. I wish You a successfull job on building it.
The K1 is an eyecatcher! I have seen some pictures of another brasilian plane. The HW4-Flamengo is also very elegant.
regards to south-america
Lothar
http://www.segelbootrefit.de/wordpress/ |
Posté le: 24/09/2007 01:03 Sujet du message: |
Thanks a lot!
All we are capable to make gliders as this.
I am happy because you also like them Brazilian gliders and Retroplanes.
Edson Nóbrega |
beat.galliker Fidèle Posteur
Posté le: 24/09/2007 06:45 Sujet du message: Minimoa of 2,2 m |
Hi Nobrega
My gratulations for your nice Minimoa!
I have an other question: In the forum Retroplane and in the internet I've found many pictures and a coloured 3-views from the Neiva B Monitor PT-PAM. That's a very interesting glider. Do you know additional data, for exemble spans or modelplan?
Thank you and I wish you a succesful job on building your nice Minimoa.
Beat |
Posté le: 24/09/2007 19:30 Sujet du message: Minimoa of 2,2 m |
Hi Edson
Thank you very much for your answer.
The 3-views and the pictures are very informativ and interesting for me. Momentary I am emplayed with two others projects. But this material is very valuable for my archives.
I wish you and your companions a good time and a lot of good flights (and landings!).
Beat |
Walter Incurable Posteur
Posté le: 24/09/2007 20:11 Sujet du message: |
Hello Edson,
...looks great your Minimoa! I´m looking forward to the further construction.
Also very interesting - the KW1 - can you write something about the specifications of your model? Span, weight, profil...
Best regards
Walter |
loopingfred Incurable Posteur
Posté le: 24/09/2007 20:44 Sujet du message: |
Hi guys,
I have moved the entire thread to this forum section as this is not really a "detailled construction in photos" subject.
Nice little project thought Even if there is too much fiberglass to me
Fred
MORE BEERS!!!! |
Posté le: 24/09/2007 21:52 Sujet du message: |
« Walter » a écrit: Hello Edson,
Best regards
Hi Walter.
Details of my KW-1:
Wing 300cm, whith 51dm2
Fuselage 130cm
Weight 2800g
Airfoil E203, E201, E193
Estab and ruder NACA 0009
The KW-1 (or Quero-Quero) is a monoplace glider projected for a Brazilian naturalized German engineer, Kuno Widmeyer. The firsth flfly was in 1968.
"The Brasilian Ministry of Aeronautics distributed the KW-1 for several aeroclubes of Brazil of 1970 to 1980.
With 156 operative produced units and currently with more than one hundred, accumulating hundreds of thousand of hours flied, they constitute absolute majority of the Brazilian gliders" ( translated of this site: http://www.ipeaeronaves.com.br/net_empresa/1971_queroquero.asp)
Edson Nóbrega |
Posté le: 25/09/2007 10:08 Sujet du message: |
Fred,
Sorry to post on wrong place!
Thanks to moved the entire thread to this forum section.
Here are more photos of the construction.
Edson Nóbrega |
