cw Accro Posteur
Posté le: 10/10/2008 23:30 Sujet du message: |
Once the primer has been brushed on, a light coat of black aerosol paint is applied to act as a guide coat...
When you start to rub the primer down, the black will show up in the low spots. Once all the black has been rubbed away, the surface will be smooth and free of blemishes...
Now the white 2-pack paint has been applied to the fuselage
 cw |
cw Accro Posteur
Posté le: 19/10/2008 17:03 Sujet du message: |
Voila, the Dart 17R is nearly completed...
Maintenant, le premier vol....!
 cw |
GuillaumeG Accro Posteur
Posté le: 19/10/2008 19:32 Sujet du message: |
Beautiful Chris!!! So I'm sure it flies great We are waiting for the video  |
Posté le: 20/10/2008 17:11 Sujet du message: |
Oouahhh.....
a lot of this month with two " meister " buildings
Paul ELLIS Fidèle Posteur
Posté le: 20/10/2008 18:48 Sujet du message: |
As usual a superb build Chris.
Thanks for all the tips, I've stolen most of them for the Minimoa.
Paul
 Un anglais en France |
Fabrice Apprenti Posteur
Posté le: 20/10/2008 21:07 Sujet du message: |
It's beautiful.
Fab |
Posté le: 21/10/2008 16:38 Sujet du message: |
Where's the tug ? Barry ! It's time!!!
Congratulations, i assume that the flight test will be a simple formality...
L |
cw Accro Posteur
Posté le: 21/10/2008 21:28 Sujet du message: |
Laurent, Barry broke his tug at Pottes, he has still not yet repaired it...
A 1st flight is never a simple formality...!
Look what happened to this one
 cw |
Posté le: 21/10/2008 21:54 Sujet du message: |
Fortunatly for Barry as the winter comes, less the repair is urgent...(more or less the same situation for me as I m retrofitting seriously my own tug)..but you're right, nothing is always granted !
Touch wood cross the fingers and thumbs up..
L |
loopingfred Incurable Posteur
cw Accro Posteur
Posté le: 25/10/2008 18:22 Sujet du message: |
So, this morning I go to White Sheet Hill...
1st, the obligatory photographs:
Now, the premier vol... (There was no one else there, so I had to take my own photos)
The Dart flies beautifully, slow, steady and very scale-like. 7 month's work validated...I am a happy man...!
 cw |
Posté le: 25/10/2008 18:37 Sujet du message: |
Congratulations Chris, your Dart is really beautiful and following the building was really interesting. Hoping you will be able to make a video soon (maybe somebody else will be better ).
Have good flights with this beauty! |
zeffus Stagiaire Posteur
Posté le: 26/10/2008 15:18 Sujet du message: |
Congratulations Chris !
It's wonderful ! And built so fast !!
Posté le: 27/10/2008 07:47 Sujet du message: |
for this first fly of this wonderfull full blood plane
Posté le: 27/10/2008 11:46 Sujet du message: |
Very great job.
Have a nice flight
Erwan |
cw Accro Posteur
Stephan Psycho Posteur
Posté le: 12/12/2008 00:29 Sujet du message: |
Congratulation Chis, looks nice your Dart with this suprisingly blue sky over England
Stephan |
Posté le: 12/12/2008 01:34 Sujet du message: |
Wonderful!
That's why I want to fly gliders
Paul
Posté le: 12/12/2008 10:19 Sujet du message: |
Motivated guys on cold conditions as your tug pilot took his ski suit!!
Congratulation to him as well !
Here can't do the same : 5 inches of snow, north wind, 0°C and above all regarding these conditions, "wooden thumbs", this is not the best to fly..
L |
Posté le: 12/12/2008 20:57 Sujet du message: |
Nice flight, Chris congratulations for this maiden
cw Accro Posteur
Chris Ze Swiss Accro Posteur
Posté le: 12/03/2009 23:53 Sujet du message: |
Hi Chris,
You spoiled us again with this beautiful video with this great glider!
Could you explain in detail your system setting the FlyCAM in front of the left wing, please?
à +, Christian
cw Accro Posteur
Posté le: 13/03/2009 00:23 Sujet du message: |
Chris, it is a simple carbon tube attached to two pieces of 12 x 3mm spruce. The spruce is laid over the wing and taped together at the trailing edge. The spruce has double-sided tape on the inside faces, which is rubbed with a thumb to make it less sticky. This helps to hold the mount in place.
 cw |
Posté le: 13/03/2009 10:22 Sujet du message: |
Beautiful flight Chris. Splendid slope. Far away from home?
I am also very impressed by the stability of your glider. Flight conditions seem to be perfect. Moderate wind. The dream of every slope soarer.
Harold |
Posté le: 14/03/2009 13:09 Sujet du message: |
Chris,
Thanks for sharing this beautifull movie;
Winter is ending, spring is coming, gliders are growing on the slope
cw Accro Posteur
Posté le: 15/03/2009 20:28 Sujet du message: |
White Sheet hill is about 1/2 hour from where I live Harold...
 cw |
Posté le: 16/03/2009 09:16 Sujet du message: |
| 30 minutes from home? You are very lucky! |
