czirh Accro Posteur
Posté le: 23/03/2009 17:54 Sujet du message: |
Left wing & aileron..
czirh Accro Posteur
Posté le: 23/03/2009 17:59 Sujet du message: |
When I finish the model, I shall try it on the slope (I have no other alternative).
(a) Model set-ups for slope soaring?
(b) The down-up movement of aileron, elevator, rudder in cm?
(c) Any additional hints on the slope soaring for this model?
(d) Any additional reinforcement on the fuselage and wings before covering?
I shall be grateful if any of you have answers to my questions!
Thank you all in advance
Cem |
Posté le: 23/03/2009 19:13 Sujet du message: |
Hi Cem
if you can, use 2 setup with your dual rate for aileron and elevator
elevator:
small: +10mm (down) / -15mm (up)
large: +15mm (down) / -20mm (up)
ailerons:
small: +10mm (down) / -18mm (up)
large: +15mm (down) / -25mm (up)
rudder: maximum... 40/45° or 50/60mm
but these valors are not critical, Doppy is not a vicious glider ![[arf]](images/smiles/arf.gif)
czirh Accro Posteur
Posté le: 23/03/2009 20:45 Sujet du message: |
Thank you very much , Vincent .. ![[good]](images/smiles/good.gif) |
czirh Accro Posteur
Posté le: 26/03/2009 19:56 Sujet du message: |
Right aileron..
czirh Accro Posteur
Posté le: 28/03/2009 08:01 Sujet du message: |
Second video:
Tow release system..
http://vimeo.com/3884231?pg=embed&sec=
I have used standard servo. Right? Or should I use a more powerful servo? |
plu ronan Incurable Posteur
Posté le: 28/03/2009 08:56 Sujet du message: |
you can used standart servo but the gra....er 5077 is good for this job  |
czirh Accro Posteur
czirh Accro Posteur
Posté le: 28/03/2009 15:17 Sujet du message: |
Canopy..:
czirh Accro Posteur
Posté le: 29/03/2009 17:18 Sujet du message: |
After painting canopy frame.
Benoit1664 Accro Posteur
Posté le: 30/03/2009 05:42 Sujet du message: |
brilliant, is your canopy.......
( dixit ma Môman...) |
czirh Accro Posteur
Posté le: 30/03/2009 17:57 Sujet du message: |
New canopy pictures..
Posté le: 30/03/2009 18:00 Sujet du message: |
very good
now, the more difficult is finish
czirh Accro Posteur
czirh Accro Posteur
Posté le: 31/03/2009 19:29 Sujet du message: |
I have started covering..
czirh Accro Posteur
Posté le: 01/04/2009 16:58 Sujet du message: |
Tail pictures..:
 Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 02/04/2009 15:02 Sujet du message: |
Fuselage pictures.
 Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 02/04/2009 15:08 Sujet du message: |
More fuselage pictures....
 Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 02/04/2009 19:57 Sujet du message: |
I plan to make it simple. Main colour white, text gray ![[good]](images/smiles/good.gif)
 Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 04/04/2009 15:09 Sujet du message: |
Wings covering..
 Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 05/04/2009 17:52 Sujet du message: |
White Doppi..
 Cem Zırh
Fafnir |
czirh Accro Posteur
Posté le: 05/04/2009 19:10 Sujet du message: |
To balance the CG, I will have to use a lot of weight (lead). May be I should use a led pilot
 Cem Zırh
Fafnir |
Posté le: 06/04/2009 05:47 Sujet du message: |
And you started the build 1 month ago
on mine, I used 200g of lead + a battery 220g
czirh Accro Posteur
Posté le: 08/04/2009 16:12 Sujet du message: |
My Doppi ... VOILA !!!
 Cem Zırh
Fafnir |
Posté le: 08/04/2009 16:30 Sujet du message: |
very nice ![[clap]](images/smiles/Clap.gif) |
Posté le: 08/04/2009 16:38 Sujet du message: |
, beautiful and more speed that your schade
patte de loup Psycho Posteur
Posté le: 08/04/2009 17:57 Sujet du message: |
Too much quik, unbelivable ..... But very nice
Congratulation
czirh Accro Posteur
Posté le: 09/04/2009 20:40 Sujet du message: |
Thank you all..
 Cem Zırh
Fafnir |
Posté le: 13/04/2009 07:10 Sujet du message: |
Hi Cem, very nice, and original with Turkish flag
soon the first flight? make a serious check-list and wait the best wind
