Minimoa 1:3.5
Rusjan
Âge: 56 Lion
MessagePosté le: 05/06/2009 11:02    Sujet du message: Minimoa 1:3.5 Répondre en citant
Hello !
Here we go again Very Happy Very Happy ... my new project is Minimoa 1:3.5 by CW...
Started with fuselage and rudder.
This is how it looks now... next step is planking the fuselage...
Regards !
Uroš
MessagePosté le: 05/06/2009 11:18    Sujet du message: Répondre en citant
Hello Uroš,
Happy to can follow a new building Very Happy
have you seen these one, from CW's plans?
http://www.retroplane.net/forum/viewtopic.php?t=2272
http://www.retroplane.net/forum/viewtopic.php?t=126
Rusjan
Âge: 56 Lion
MessagePosté le: 05/06/2009 12:34    Sujet du message: Minimoa ! Répondre en citant
Hello Uroš,
Vincent thanks for the links Very Happy Very Happy ... I 've been looking at cw building log on RC-groups (3rd Minimoa) but these two that you gave are [clap] [clap] ....
Regards !
Uroš
MessagePosté le: 06/06/2009 10:08    Sujet du message: Répondre en citant
Hi Uros
great to be able to follow your building. That also proofs which huge communitiy Retroplane becomes, from all over the world [good]
Cheers
Rusjan
Âge: 56 Lion
MessagePosté le: 11/06/2009 22:50    Sujet du message: Minimoa ! Répondre en citant
Some progress in past few days Very Happy Very Happy ...
epoxy resin and glass fabrics were put in the cockpit area
sanded before car filler was added
and sanding...
not finsihed yet, but prepared for further work
Regards !
Uroš
Rusjan
Âge: 56 Lion
MessagePosté le: 27/06/2009 18:28    Sujet du message: Minimoa ! Répondre en citant
Some progress....
elevator
balsa ribs were removed
wheel already positioned
elevator on the fuselage
rudder still need some work
test pilot already inspecting
Regards !
Uroš
Rusjan
Âge: 56 Lion
MessagePosté le: 05/08/2009 08:17    Sujet du message: Minimoa ! Répondre en citant
Some work was done on the elevator connection...
fixed on the fuselage...
in action Very Happy ...
http://www.youtube.com/watch?v=frEnnwaE0AU
Regards !
Uroš
Rusjan
Âge: 56 Lion
MessagePosté le: 26/09/2009 11:47    Sujet du message: Minimoa! Répondre en citant
Finally some progress...
Fuselage almost covered...
wing joiner mounted in the fuselage..
Al template for the ribs nad some already cut from plywood..
ribs on balsa sheet..
"Big Mac" Cool ...
ribs finished...
Regards !
Uroš
Rusjan
Âge: 56 Lion
MessagePosté le: 26/09/2009 14:21    Sujet du message: Minimoa ! Répondre en citant
Here we go Very Happy Very Happy ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 26/09/2009 18:55    Sujet du message: Minimoa ! Répondre en citant
And here is the result of today's work Very Happy Very Happy Very Happy ... 2 meters done, 3 to go Cool ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 29/09/2009 14:39    Sujet du message: Minimoa ! Répondre en citant
Still missing some three meters of wing Cool , but slowly it looks like the real one Wink Wink ...
Regards !
Uroš
Âge: 61 Gémeau
Nouveau messagePosté le: 29/09/2009 16:14    Sujet du message: Répondre en citant
Hallo Uros,
it's locking good your Mini Moa [clap] [clap] , you work fast and cleanly.
Geetings Peter
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 29/09/2009 19:51    Sujet du message: Répondre en citant
« Peter64 » a écrit:
Hallo Uros,
Geetings Peter
Thanks... I hope there will be more time for the building in coming days, since building and construction activities around the house are done Very Happy .
By the way your Mg-19 looks smashing [clap] [clap] ...
Regards !
Uroš
Âge: 61 Gémeau
Nouveau messagePosté le: 30/09/2009 12:10    Sujet du message: Répondre en citant
Hallo Uros, Very Happy
thank you for the compliment, for this time I make the varnishing by the fuselage and the wings.
Uros what material you want to use covering for your wings and empennage?
Greetings Peter
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 30/09/2009 13:18    Sujet du message: Minimoa ! Répondre en citant
I was thinking about oratex, since I have good experience with it from my previous project. Fuselage will be probably painted in a "CW " way.
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 15/10/2009 20:04    Sujet du message: Minimoa ! Répondre en citant
Some more progress...
tow hook...
from inside...
some more work done in wing-fuselage area...
prepared for finsh...
Nose still needs to be closed. Models for nose weights are already prepared and will be casted as soon as plaster moulds dry out.
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 18/10/2009 17:36    Sujet du message: Minimoa ! Répondre en citant
Today some work was done on the air brakes...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 28/10/2009 20:46    Sujet du message: Minimoa ! Répondre en citant
Some more work done Very Happy Very Happy ...
the garden looks rather small now Wink ...
Regards !
Uroš
Klaus69
Âge: 56 Sagittaire
Nouveau messagePosté le: 29/10/2009 08:43    Sujet du message: Répondre en citant
Well done! It looks realy nice. Hope we will see pictures from the maiden flight Wink
Âge: 61 Gémeau
Nouveau messagePosté le: 29/10/2009 10:35    Sujet du message: Répondre en citant
perfect work that you have made, [clap] [amen] .
Geetings Peter
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 29/10/2009 20:14    Sujet du message: Minimoa ! Répondre en citant
Thanks, guys Cool Cool ... There will sure be some more photos and hopefully also the video of the maiden flight Very Happy ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 04/11/2009 21:29    Sujet du message: Minimoa ! Répondre en citant
Lead weights in the nose...
and finish...
Regards !
Uroš
Âge: 61 Gémeau
Nouveau messagePosté le: 05/11/2009 20:21    Sujet du message: Répondre en citant
tell me please, how much gram are the weight in the nose?
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 05/11/2009 20:57    Sujet du message: Minimoa ! Répondre en citant
Hello Peter !
All 4 pieces are just a few grams below 1kg...
Regards !
Uroš
DirkBoehm
Âge: 48 Balance
Nouveau messagePosté le: 05/11/2009 21:50    Sujet du message: Répondre en citant
Hello Uros,
beautiful piece of work, that you present here. [clap]
I love those gullwing sailplanes.
Keep up the good work and let us know about any progress.
Cheers,
Dirk.
BTW: Almost as impressive as the Minimoa is your lawn. Nice grass, just like on a golf course. I wish mine would look half that good Wink
Viele Grüße,
Dirk.
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 05/11/2009 22:31    Sujet du message: Minimoa ! Répondre en citant
« DirkBoehm » a écrit:
Hello Uros,
Thanks Very Happy .... Here is another one from Kranich II project Wink ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 02/12/2009 08:54    Sujet du message: Minimoa ! Répondre en citant
Wings are almost ARC Very Happy ... Still some work sould be done on the wing tips and front end of the wing...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 25/02/2010 14:21    Sujet du message: Minimoa ! Répondre en citant
Almost finished Very Happy ... There is still some work regarding fuselage but I hope it will be done in next days...
Regards !
Uroš
Âge: 61 Gémeau
Nouveau messagePosté le: 25/02/2010 20:37    Sujet du message: Répondre en citant
Salut Uros,
your glider looks like perfect [clap] [amen] .
congratulations
cw
Âge: 78 Sagittaire
Nouveau messagePosté le: 25/02/2010 23:42    Sujet du message: Répondre en citant
Nice job, Uroš...
cw
Page 1 sur 3
