Fafnir 4m - Cem
1, 2, 3, 4, 5, 6 Suivante
czirh
Âge: 63 Sagittaire
MessagePosté le: 19/10/2009 14:54    Sujet du message: Répondre en citant
I think bell crank sistem..? [humm] Because, this place very small..? [argh]
Cem Zırh
Fafnir
MessagePosté le: 19/10/2009 15:06    Sujet du message: Répondre en citant
Hi Cem, sorry but I don't know what is "bell crank system" you want to have an idea to make link to the rudder with cables? or a system for the elevator?
czirh
Âge: 63 Sagittaire
MessagePosté le: 19/10/2009 15:27    Sujet du message: Répondre en citant
Hi Vincent,
I use bell crank system the elevator.
This plan:
this example:
Cem Zırh
Fafnir
MessagePosté le: 19/10/2009 16:35    Sujet du message: Répondre en citant
Very small place and need to be strong [humm] perhaps you can get tips and inspiration with the system on the RRG Professor http://www.retroplane.net/forum/viewtopic.php?t=2028
If it was for me, I build a system with ball bearings
czirh
Âge: 63 Sagittaire
MessagePosté le: 20/10/2009 16:24    Sujet du message: Répondre en citant
Today..
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 21/10/2009 13:35    Sujet du message: Répondre en citant
Christian Wink
Thank you, Christian.. Very Happy
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 21/10/2009 13:43    Sujet du message: Répondre en citant
This is (my.!) bell crank system.. [humm]
It is work, but not rugged now...! [arf]
Cem Zırh
Fafnir
tuzkanh
Âge: 55 Cancer
MessagePosté le: 21/10/2009 17:27    Sujet du message: Répondre en citant
Abi çok güzel gidiyor kolay gelsin
czirh
Âge: 63 Sagittaire
MessagePosté le: 21/10/2009 17:46    Sujet du message: Répondre en citant
Teşekkür ederim Hakan' cığım. Retroplane Forum' a hoş geldin. Very Happy
Thank you Hakan. Welcome to Retroplane Forum.
Cem
Cem Zırh
Fafnir
MessagePosté le: 21/10/2009 18:42    Sujet du message: Répondre en citant
Hi Hakan, welcome to the forum, welcome to the Turkey Very Happy
tuzkanh
Âge: 55 Cancer
MessagePosté le: 21/10/2009 19:46    Sujet du message: Répondre en citant
Cem abi teşekkür ederim
Thank you Vincent
czirh
Âge: 63 Sagittaire
MessagePosté le: 22/10/2009 18:28    Sujet du message: Répondre en citant
Rudder and elevator video...
Rudder pull-pull , elevator bellcarank system.
http://www.youtube.com/watch?v=3mUd3oCicVU
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 23/10/2009 15:21    Sujet du message: Répondre en citant
skid making..
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 25/10/2009 14:05    Sujet du message: Répondre en citant
release system:
servo: robbe-futaba s9202
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 26/10/2009 18:09    Sujet du message: Répondre en citant
fuselage construction..
Cem Zırh
Fafnir
MessagePosté le: 26/10/2009 18:43    Sujet du message: Répondre en citant
Bonne construction Cem [clap]
It's very interesting your release system [good]
czirh
Âge: 63 Sagittaire
MessagePosté le: 29/10/2009 10:18    Sujet du message: Répondre en citant
What is the simplest method of this cutting process? [humm]
Thanks..
Cem Zırh
Fafnir
MessagePosté le: 29/10/2009 10:48    Sujet du message: Répondre en citant
Hi Cem
You can cut with a small blade of electric saw in a X-Acto or a diamond disk
But me, I prefere to cover the fuselage without the canopy, and build and adjust the canopy in a second time...
czirh
Âge: 63 Sagittaire
MessagePosté le: 29/10/2009 15:40    Sujet du message: Répondre en citant
Hi Cem
Thank you Vincent.
I think the second.. [humm]
I need to change belkrank system ..
Because , after the sanding it will not work... [argh]
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 29/10/2009 18:17    Sujet du message: Répondre en citant
Joiner tube..
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 30/10/2009 18:19    Sujet du message: Répondre en citant
wing&fuselage connection
Cem Zırh
Fafnir
Lothar Mentz
MessagePosté le: 31/10/2009 10:26    Sujet du message: Répondre en citant
Hi Cem,
it's a beautifull glider and a great job You are doing.
[amen] [amen] [amen]
Thank You for this detailed build-log. [clap]
Regards
Lothar
czirh
Âge: 63 Sagittaire
MessagePosté le: 31/10/2009 15:49    Sujet du message: Répondre en citant
« Lothar Mentz » a écrit:
Hi Cem,
Regards
Lothar
Hi Lothar;
Thank you for the compliment .. Very Happy
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 31/10/2009 15:54    Sujet du message: Répondre en citant
Today I made a simple stand for Fafnir. This is very important.
Cem Zırh
Fafnir
MessagePosté le: 31/10/2009 17:28    Sujet du message: Répondre en citant
[good] With that, it is more easy to work on the fuselage, we should make everytime a stand in first.
tuzkanh
Âge: 55 Cancer
MessagePosté le: 31/10/2009 20:36    Sujet du message: Répondre en citant
Cem abi çok iyi gidiyor kolay gelsin
Hakan Tuzkan
Ankara/Türkiye
jorge antonio
Âge: 56 Sagittaire
MessagePosté le: 01/11/2009 02:50    Sujet du message: Répondre en citant
Hi Cem,
Beautiful bird, congratulations for the construction.
Jorge [clap]
czirh
Âge: 63 Sagittaire
MessagePosté le: 01/11/2009 19:05    Sujet du message: Répondre en citant
Elevator servo: Hextronik HX12K
Type: Digital
Gearing: Metal
Weight: 55g
Size: 40.7 x 19.7 x 42.9mm
speed (4.8v): 0.17sec/60degrees
speed (6.0v): 0.13sec/60degrees
stall torque(4.8v): 13kg/cm
stall torque(6.0v): 15kg/cm
Temperature Range: -30 to +60 Degree C
Dead Band Width: 4usec
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 05/11/2009 21:36    Sujet du message: Répondre en citant
Good evening,
Fafnir procekt will delay. My right leg broke from two points. Operation tomarrow morning. [argh] 24 24
Cem Zırh
Fafnir
MessagePosté le: 05/11/2009 21:50    Sujet du message: Répondre en citant
Aïe, it's bad news, I hope that your operation will be good
Page 2 sur 6
