SZD 12 Mucha 100
RobertoP
Âge: 61 Balance
MessagePosté le: 09/08/2009 09:10    Sujet du message: SZD 12 Mucha 100 Répondre en citant
Hi All,
is the first time for me on this forum an for this reason I present me, I am an Italian modeller and I am very enthusiastic for building scale glider. I am following this forum from many time and I thanks Vincent for the very beautiful forum from where I have learned many things regarding building glider. Following the method of construction of Musger, I made the my first project of glider totally build in balsa an plywood the SZD12 Mucha-100 1/5 semi scale. I enclose some pictures of the building of my glider and some photo of the finish model.
Unfortunately I have no photo of model flying but from my firs flight tests, seems that the model flight well.
The characteristics of model are the following:
Wingspan 3m
weight 3.2kg
profile HQ 30-12
If someone is interested to the project in CAD format I can sent it by e-mail.
Again many compliments for the forum that for me is one of the beautiful on web.
Roberto
MessagePosté le: 09/08/2009 09:23    Sujet du message: Répondre en citant
Hello Roberto, welcome to the forum Very Happy
Very nice model, with what you covered it? solartex?
later, when you will have some photo in flight, post them please Very Happy
MessagePosté le: 09/08/2009 10:39    Sujet du message: Répondre en citant
Hello Roberto, welcome to the forum .
This model is very nice.
cassin jean
Âge: 76 Lion
MessagePosté le: 09/08/2009 13:36    Sujet du message: Répondre en citant
C'est pour ça que tu peux faire des planeurs verts Vincent , tu es sure de les retrouver , pas nous ... [non]
RobertoP
Âge: 61 Balance
MessagePosté le: 09/08/2009 13:53    Sujet du message: Répondre en citant
Hello Vincent,
the wing and the moving part of tailplane are covered with Oratex and painted with acrylic two components paint.
Roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 11/08/2009 20:40    Sujet du message: Other images Répondre en citant
Hello,
I insert other images of construction and the image of my project.
Roberto
klajmen
MessagePosté le: 04/01/2010 17:42    Sujet du message: Répondre en citant
Hi Roberto
I am the owner built, the model glider (SP-1819).
Congratulates the beautiful model and I am glad that painted it looks like my copy. If you need accurate information about the scheme please painting. I will send you detailed drawings. In Poland such a model was built Thomas Swiderski http://www.bakcyl.systemart.pl/index.html?grp=19 you can compare with her. In my opinion, you are more successful.
Caesar
MessagePosté le: 04/01/2010 19:11    Sujet du message: Répondre en citant
Hi Caesar, welcome to the forum Very Happy
Please Roberto, a friend of mine would like to build the Mucha, but a little bit more large, do you sell your plan, printed on paper? it will be possible to buy it enlarged? for the moment I don't know exactly the size he want, around 3.50m... thank you Wink
czirh
Âge: 62 Sagittaire
MessagePosté le: 04/01/2010 20:54    Sujet du message: Répondre en citant
Hi Roberto;
Nice sailplane, congratulations..
Cem Zırh
Fafnir
RobertoP
Âge: 61 Balance
MessagePosté le: 05/01/2010 00:00    Sujet du message: Répondre en citant
Many thanks for the congratulation, herer enclose some photos of flight test, unefortunately the photos are not so good.
Roberto
Zeitweise
Âge: 66 Scorpion
Nouveau messagePosté le: 05/01/2010 00:43    Sujet du message: Mucha 100 - MuchaStandard Répondre en citant
Wonderful work Roberto! [clap]
What a coincidence I am also drawing a plan of the Mucha Standard at the moment in 1:5.
I like your work. Could you put a few more information of the construction on the net. Did you use mostly Balsa for the fuselage - what material did you use for the formers and the longerons?
Please also contribute a few details about wingconstruction.
Regards
Alexander
Zeitweise
Âge: 66 Scorpion
Nouveau messagePosté le: 06/01/2010 16:47    Sujet du message: Original Répondre en citant
I found a few photographes from Mucha 100 to be refurbished.
Please enjoy.
Alexander
RobertoP
Âge: 61 Balance
Nouveau messagePosté le: 06/01/2010 22:16    Sujet du message: Re: Mucha 100 - MuchaStandard Répondre en citant
Regards
Alexander
Dear Alexander,
regarding the construction of my Mucha I have followed the method of construction of Vincent's Musger MG19,for the fuselage the formers are in 3mm light plywood and covered with 3mm balsa, the longerons are 3x6mm pine. The spare of wings are in pine 4x10mm end the ribs are in 2mm balsa, the spare are faced with 2mm balsa on both side. The wings are covered with 1.5mm balsa.
Unfortunately I have no other photos of wings during construction, anyway if you like I can sent you my project were you can check in more detail the method of construction.
Regards
Roberto
RobertoP
Âge: 61 Balance
Nouveau messagePosté le: 06/01/2010 22:30    Sujet du message: Répondre en citant
« klajmen » a écrit:
Hi Caesar,
a photo of my model in about the same position of your photo.
Roberto
klajmen
Nouveau messagePosté le: 07/01/2010 10:31    Sujet du message: Répondre en citant
Roberto super MDR
Nouveau messagePosté le: 24/01/2010 09:47    Sujet du message: Répondre en citant
Many thank Roberto from my friend Gérald, enlarged your files, span 3.60m and he started the building
klajmen
Nouveau messagePosté le: 24/01/2010 10:21    Sujet du message: Répondre en citant
New Mucha 100 France ???!!! SUPER MDR France flew the original one Mucha 100. Unfortunately, I do not have the pictures and I do not know its history. Vincent, if you need pictures or paint scheme write.
Roberto if you can get the plans from your model?
RobertoP
Âge: 61 Balance
Nouveau messagePosté le: 24/01/2010 14:32    Sujet du message: Répondre en citant
Hi Vincent,
I am very happy Very Happy that your friend Gérald has appreciated my project ,for me is a beautiful thing to share my drawings with other enthusiastic of vintage glider.
Many congratulation to Gérald for the very good construction [clap] , the 3.6m is a very good size.
For Klajmen, if you send me your e-mail I can send you the CAD fail of my project.
Regards
Roberto
Nouveau messagePosté le: 19/04/2010 20:05    Sujet du message: Répondre en citant
Les dernières photos du Mucha de Gérald, il ne lui reste plus que la finition à faire [clap]
Nouveau messagePosté le: 19/04/2010 20:10    Sujet du message: Répondre en citant
beau boulot
et un atelier mieux rangé que le mien Laughing
Âge: 78 Balance
Nouveau messagePosté le: 19/04/2010 21:16    Sujet du message: Répondre en citant
Oui, beau travail et l'atelier n'est pas mal non plus, et chauffé en plus !!
RobertoP
Âge: 61 Balance
Nouveau messagePosté le: 19/04/2010 22:49    Sujet du message: Répondre en citant
i Vincent
again many compliment to Gerald for the construction. I need to apologize with you and Gerald but I have checked the CG indication on my drawing and I need to underline that the position indicated is wrong,
Embarassed you need to move forward the position of CG of about 5mm. Obviously considering that you have scaled my drawings you need to recalculate the position. Moving the CG 5mm forward the CG is placed at 39% of medium chord.
Regards
Roberto
Nouveau messagePosté le: 16/11/2010 11:33    Sujet du message: Répondre en citant
Ci-joint plan détaillé du grandeur que m'a envoyé Roberto
a noter qu'avec IE, ce gif en trés haute résolution ne s'ouvrira peut être pas, faites dans ce cas un clic droit sur la vignette/enregistrer la cible sous... sinon pas de soucis d'ouverture avec FireFox et Chrome
ainsi que ce lien avec de nombreuses photos du Mucha100
http://www.freefly.sk/modules.php?name=FotoGaleria&file=thumbnails.....page=1&sort
 Taille du fichier:  800.75 Ko
 Vu:  1907 fois
cassin jean
Âge: 76 Lion
Nouveau messagePosté le: 16/11/2010 13:21    Sujet du message: Répondre en citant
Et non , avec IE , même en faisant "enregistrer la cible sous .." ça ne veut pas marcher . J'obtiens un grand carré blanc avec une petite croix rouge en haut à droite ...
Salut Vincent .
Nouveau messagePosté le: 16/11/2010 13:24    Sujet du message: Répondre en citant
Si tu fais enregistrer la cible sous... ça t'enregistre le fichier là où tu veux, bureau, mes docs... donc après t'ouvres ce fichier avec la visionneuse windows ou autre soft, sauf IE Wink
cassin jean
Âge: 76 Lion
Nouveau messagePosté le: 16/11/2010 13:30    Sujet du message: Répondre en citant
Ok merci , je vais essayer !
Salut .
