uav-oscar Apprenti Posteur
Posté le: 03/03/2011 21:48 Sujet du message: |
Tesekkurler abi..  |
Posté le: 04/03/2011 06:24 Sujet du message: |
This is the first Doppi in Turkey which build from Cem Zirh and mine will be the second one..
Posté le: 04/03/2011 11:04 Sujet du message: |
Posté le: 04/03/2011 23:45 Sujet du message: |
Thanks Christian... |
Posté le: 05/03/2011 00:01 Sujet du message: |
Tomorrow I will start building the wings..
But tonight I have a problem... I do not know if its dxf mistake or my laser cut machine problem???
Main spar shown 5x10mm on the plan & dxf, but all ribs (balsa & plywoods) have 6x10mm cut for spar..
As a solution I cut tiny pieces from 1mm balsa and glue it every ribs on the wing..
Posté le: 05/03/2011 00:04 Sujet du message: |
I fix this problem but it took long time.. I am ready for wing construction now..
Posté le: 05/03/2011 06:51 Sujet du message: |
I re-checked the dxf is well 10x5mm
Strange indeed that the cuts are at 11mm
There is not a bad parameter cutting, which cuts outside the lines?
Posté le: 05/03/2011 17:42 Sujet du message: |
Some details on wing construction..
I use carbon tubes for wing joiner..
Dihedral...
Posté le: 05/03/2011 17:43 Sujet du message: |
Posté le: 05/03/2011 17:47 Sujet du message: |
My friend Osman abi help me a lot for the wing construcion.. Honestly as I did not build scratch style for long years, I request him to help me..
He is a more then 40 years modeling experience ( especially Free Flight), also he is building http://www.retroplane.net/forum/viewtopic.php?t=3310
Zlin Z-24 ..
Thank you Osman abi.. ![[amen]](images/smiles/amen.gif) |
Posté le: 05/03/2011 17:50 Sujet du message: |
Posté le: 05/03/2011 17:52 Sujet du message: |
Now I am waiting for drying time of Aliphatic glue..
Posté le: 05/03/2011 20:02 Sujet du message: |
It's nice to work with friends Good job ![[clap]](images/smiles/Clap.gif) |
Posté le: 05/03/2011 21:08 Sujet du message: |
Aliphatic glue dry at the end..
Posté le: 05/03/2011 21:10 Sujet du message: |
Now Shear web time..
Posté le: 05/03/2011 22:13 Sujet du message: |
Viva Andino balsa ! Why not Rétroplane in Turkey in the next years ? ...Do you have convenient slope soaring places?  |
Jac50 Maniaco Posteur
Posté le: 06/03/2011 10:29 Sujet du message: |
Congratulation,
It's a good job, well and quickly done.
I will follow your construction.
Friendly.
Jacques.
(Jacques Rouxel). |
Posté le: 06/03/2011 10:36 Sujet du message: |
Thank you Jacques...
We are lucky that Vincent have dxf plans of Doppi, which makes us much quicker construction by the help of laser cut.. ![[clap]](images/smiles/Clap.gif) |
Posté le: 09/03/2011 14:42 Sujet du message: |
So much snow for today and I prefer to stay home
Posté le: 09/03/2011 14:45 Sujet du message: |
Still building left wing..
I could not cut triangles same
Posté le: 09/03/2011 15:15 Sujet du message: |
Ho snow at Ankara, very rare no? ![[humm]](images/smiles/humm.gif)
Posté le: 09/03/2011 16:53 Sujet du message: |
For March this much snow is not usual Vincent..
But it gave me a full free day for Doppi construction  |
Posté le: 09/03/2011 18:33 Sujet du message: |
Last 17 years , we did not have this much snow ( from tv news )
45 cm. snow on the top of my car
My wife car ( hard to believe but its a WW Golf )
I spend 1.5 hours to plow the snow
Posté le: 09/03/2011 18:57 Sujet du message: |
You're right, it's better to stay in the workshop, good weather for progress in building  |
Posté le: 10/03/2011 22:16 Sujet du message: |
At the end left wing is out of stand..
Posté le: 10/03/2011 22:18 Sujet du message: |
Right now weight looks good..
