Minimoa of 2,2m
nobrega
MessagePosté le: 23/09/2007 12:29    Sujet du message: Minimoa of 2,2m Répondre en citant
Hi.
I am making a Minimoa of 2,2 meters.
Here are some pictures of the fuselage plug.
I make a drawing of three view picture and make the plug. I am planning to make the fuselage on fiber glass and the wings of balsa wood.
Je suis en train de faire un Minimoa en 2.2m
Voici quelques photos du master du fuselage.
J'ai fais le master a partir d'un plan 3 vues. Je vais faire le fuselage en fibre et les ailes en structure
This is pictures is a KW-1 glider, a brasilian glider of 1960...
I like a lot of "Retroplanes" Very Happy
Voici des photos du KW-1, un planeur Bresilien des années 1960.
J'aime bien les Retroplanes (planeurs rétro)
Edson Nóbrega
Lothar Mentz
MessagePosté le: 24/09/2007 00:12    Sujet du message: Répondre en citant
Hi Nobrega,
Your pictures are looking great. I wished I would be as far as You with my projects.
I think a 2.2 m Minimoa is a great to handle sweet airplane. I wish You a successfull job on building it.
The K1 is an eyecatcher! I have seen some pictures of another brasilian plane. The HW4-Flamengo is also very elegant.
regards to south-america
Lothar
nobrega
MessagePosté le: 24/09/2007 02:03    Sujet du message: Répondre en citant
Thanks a lot!
All we are capable to make gliders as this.
I am happy because you also like them Brazilian gliders and Retroplanes.
Edson Nóbrega
beat.galliker
Âge: 84 Sagittaire
MessagePosté le: 24/09/2007 07:45    Sujet du message: Minimoa of 2,2 m Répondre en citant
Hi Nobrega
My gratulations for your nice Minimoa!
I have an other question: In the forum Retroplane and in the internet I've found many pictures and a coloured 3-views from the Neiva B Monitor PT-PAM. That's a very interesting glider. Do you know additional data, for exemble spans or modelplan?
Thank you and I wish you a succesful job on building your nice Minimoa.
Beat
nobrega
MessagePosté le: 24/09/2007 18:06    Sujet du message: Re: Minimoa of 2,2 m Répondre en citant
« beat.galliker » a écrit:
Hi Nobrega
Beat
Hi Beat,
Here are a three view of Neiva Glider http://mmb.internethost.com.br/aero/img/scan.zip
If you are found plans of this glider http://www.amp.esp.br/fotos.htm my friend Mborges is drawing in Autocad a plan of Neiva B.
If do not was this glider, please send me a link of the site...
I sent an email for he and I am waiting the reply.
I'll send to you a copy of DXF drawing...
Edson Nóbrega
beat.galliker
Âge: 84 Sagittaire
MessagePosté le: 24/09/2007 20:30    Sujet du message: Minimoa of 2,2 m Répondre en citant
Hi Edson
Thank you very much for your answer.
The 3-views and the pictures are very informativ and interesting for me. Momentary I am emplayed with two others projects. But this material is very valuable for my archives.
I wish you and your companions a good time and a lot of good flights (and landings!).
Beat
MessagePosté le: 24/09/2007 21:11    Sujet du message: Répondre en citant
Hello Edson,
...looks great your Minimoa! I´m looking forward to the further construction. Very Happy
Also very interesting - the KW1 - can you write something about the specifications of your model? Span, weight, profil...
Best regards
Âge: 50 Gémeau
MessagePosté le: 24/09/2007 21:44    Sujet du message: Répondre en citant
Hi guys,
I have moved the entire thread to this forum section as this is not really a "detailled construction in photos" subject.
Nice little project thought Very Happy Even if there is too much fiberglass to me Wink
Fred
nobrega
MessagePosté le: 24/09/2007 22:52    Sujet du message: Répondre en citant
« Walter » a écrit:
Hello Edson,
Best regards
Hi Walter.
Details of my KW-1:
Wing 300cm, whith 51dm2
Fuselage 130cm
Weight 2800g
Airfoil E203, E201, E193
Estab and ruder NACA 0009
The KW-1 (or Quero-Quero) is a monoplace glider projected for a Brazilian naturalized German engineer, Kuno Widmeyer. The firsth flfly was in 1968.
"The Brasilian Ministry of Aeronautics distributed the KW-1 for several aeroclubes of Brazil of 1970 to 1980.
With 156 operative produced units and currently with more than one hundred, accumulating hundreds of thousand of hours flied, they constitute absolute majority of the Brazilian gliders" ( translated of this site: http://www.ipeaeronaves.com.br/net_empresa/1971_queroquero.asp)
Edson Nóbrega
nobrega
MessagePosté le: 25/09/2007 11:08    Sujet du message: Répondre en citant
Fred,
Sorry to post on wrong place! Confused Confused
Thanks to moved the entire thread to this forum section.
Here are more photos of the construction.
Edson Nóbrega
