czirh Accro Posteur
Posté le: 07/08/2009 20:52 Sujet du message: Aileron - servo |
Can I use this servo :
DS-929MG
Corona Digital Servo 2.2kg / 12.5g / .11sec
Features.
Ball bearing support
Programmable Digital, with MOSFET Drive
Metal gearing
High Speed & High Torque
Speed: .11sec/60deg @ 4.8v
Stall Torque: 2.2kg.cm @ 4.8v
Standing Torque: 2.2kg.cm/5deg hold out
Weight: 12.5g
for the 3.3m wingspan Grunau Baby 's ailerons?
 Cem Zırh
Fafnir |
texier Accro Posteur
Posté le: 08/08/2009 01:26 Sujet du message: |
Hello Czirh,
The technical datas of this servo look good (enought torque, metal geared) even I don't know this mark (quality ? ).
Therefore I would choose a bigger one because your glider will have large and probably heavy ailerons causing relative strength (later movements) between servo and structure. With a bigger size the servo's case will be better maintened in my opinion.
In all cases the metal geared servos are necessary with small servos.
I remember a glider with which one I had plastic gear to replace after each landing
Good luck
 Sylvain.
Posté le: 08/08/2009 08:56 Sujet du message: |
Hello
If you have more place in the wings, take biggest servos (C5077 for exemple, it's not very expensive , more torque than DS-929 mg and better resistant for choc)
Erwan |
czirh Accro Posteur
Posté le: 08/08/2009 19:21 Sujet du message: |
Thanks , Texier and Erwan.
Bigger servo is better for the ailerons.
 Cem Zırh
Fafnir |
