1: 3.25 scale MG19a Steinadler
1, 2, 3, 4, 5 Suivante
cw
Âge: 78 Sagittaire
MessagePosté le: 18/01/2009 23:03    Sujet du message: Répondre en citant
The main airframe is now built, so things slow down a bit as the more detailed work needs to be done...
The basic, unshaped aileron is hinged with Robart hinges and attached to the wing...
Now the aileron is sanded to fit the wing...
Today, the aileron has been fitted out with all the detail work, and the wing tip shroud finished off...
The servo and linkage are also fitted in...
Then I went flying with the Dart 17... Very Happy Very Happy Very Happy Very Happy Very Happy
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 24/01/2009 17:47    Sujet du message: Répondre en citant
Today, a chance to see the assembled planeur...
cw
Âge: 50 Gémeau
MessagePosté le: 24/01/2009 20:28    Sujet du message: Répondre en citant
[clap] Wow, looking really good Chris !
What is the weight so far ?
cw
Âge: 78 Sagittaire
MessagePosté le: 25/01/2009 11:57    Sujet du message: Répondre en citant
I don't know the weight so far, Fred, but I expect it to end up very similar to the Minimoa at 11-12kgs...
cw
MessagePosté le: 25/01/2009 16:01    Sujet du message: Répondre en citant
No doubt the gull wing variant of the Musger is very nice and your job/commitment/patience is remarkable..
Bravo..
cw
Âge: 78 Sagittaire
MessagePosté le: 01/02/2009 16:12    Sujet du message: Répondre en citant
This is the bit I've been putting off until last...the airbrakes!
To make sure they close properly in flight my airbrakes are to be spring-loaded
Cutting out the ribs for the airbrake assembly
Now they are glued into the wing
Finishing off the bottom sheeting
It works Very Happy Very Happy Very Happy
The wings are now just about complete. Fred, the model weighs 20lbs (9Kg) at this stage, that is with some ballast built in the nose. The CG is on the spar at the moment
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 14/02/2009 22:13    Sujet du message: Répondre en citant
I have spent the last week working in the cockpit area...
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 26/02/2009 00:27    Sujet du message: Répondre en citant
Working at the rear end again... this is the fairing for the fin/tailplane
The tailplane is now properly sorted out, and since this photo was taken, all the flying surfaces have been covered with Natural Solartex...
cw
MessagePosté le: 26/02/2009 02:57    Sujet du message: Répondre en citant
Hi Chris ,
What kind of solution do you have implemented to be sure no weakness
appears on the base of tail due to the notch? [humm] Is there any additional support inside the tail? [humm] I am interessting about that for a futur scale plane. In that case, I am little bit concerned regarding the the landing impact. Rolling Eyes
KR
Benoit1664
Âge: 66 Scorpion
MessagePosté le: 26/02/2009 10:25    Sujet du message: Répondre en citant
ohhhh, brilliant building
( dixit ma Môman...)
cw
Âge: 78 Sagittaire
MessagePosté le: 26/02/2009 21:39    Sujet du message: Répondre en citant
Pat, I was surprised when I removed the 2mm balsa sheeting how strong the tailplane still was. (The brick weighs 2Kgs!)
The tailplane rear spar is made from 6mm hard balsa and is reinforced with 6mm triangular section to make the hollow for the elevator leading edge. Into this are some quite large holes for the hinge dowels, but of course the elevator leading edge adds strength too once it is fixed into place... The MG19a is not an aerobatic machine, so I think it would take a lot of speed or a very heavy landing to break it...
cw
Paul ELLIS
Âge: 79 Verseau
MessagePosté le: 28/02/2009 23:43    Sujet du message: Répondre en citant
Hi again Chris
Just for the record, how much Solartex did it take?
TIA
Paul
Un anglais en France
cw
Âge: 78 Sagittaire
MessagePosté le: 01/03/2009 10:17    Sujet du message: Répondre en citant
I started off with 10m roll, Paul, but I've had to buy an extra 3m for the fuselage...
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 05/03/2009 20:51    Sujet du message: Répondre en citant
Deep into the painting process now, so progress is sloooow!
The whole airframe is covered in Solartex
Al the 'Tex joins are sprayed with 2-pack primer in order to lose them
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 13/03/2009 22:25    Sujet du message: Répondre en citant
Still deep into the painting process...
The wings have been sprayed with 2 coats of 2K lacquer and are now being rubbed down wet with 600grit paper, ready for the next application of lacquer...
The tail end is almost completed...
These are some of the parts to go into the cockpit, nearly 600gms
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 20/03/2009 00:13    Sujet du message: Répondre en citant
Now I am approaching the finish... I would hope to be ready for flight around Easter time...
cw
MessagePosté le: 20/03/2009 07:25    Sujet du message: Répondre en citant
Hoo very nice [clap] you paint with spray gun?
Nouveau messagePosté le: 20/03/2009 10:07    Sujet du message: Répondre en citant
nice Chris, [clap]
Take care at Easter to not meet some belts during the flight MDR
Serouisly , impatient to see this beautifull bird in the sky Wink
Video may be [humm]
Paul ELLIS
Âge: 79 Verseau
Nouveau messagePosté le: 20/03/2009 10:26    Sujet du message: Répondre en citant
Absolutely beautiful Chris [amen]
What masking tape do you use?
cw
Âge: 78 Sagittaire
Nouveau messagePosté le: 21/03/2009 22:39    Sujet du message: Répondre en citant
Today, the Steinadler is rigged for the 1st time since painting...
Vincent, oui, the paint is sprayed on (That is my profession)
Paul, I use 3M Fine Line tape for masking the trim colours, but it is essential to ensure that the Solartex weave is filled enough with the 1st coats of paint to prevent the trim colour 'bleeding' under the tape...
Pat, I am impatient too, and a little scared Wink Wink
cw
GuillaumeG
Âge: 41 Vierge
Nouveau messagePosté le: 21/03/2009 23:05    Sujet du message: Répondre en citant
Beautiful Chris, as always!! What a sunny day in England Cool
Jürgen
Âge: 59 Gémeau
Nouveau messagePosté le: 22/03/2009 11:52    Sujet du message: Répondre en citant
Wonderful, absolutely perfect, Chris.
[clap]
[clap]
[clap]
Jürgen
Nouveau messagePosté le: 22/03/2009 13:14    Sujet du message: Répondre en citant
it's huge, it's amazing.. Enjoy for the first fly
czirh
Âge: 63 Sagittaire
Nouveau messagePosté le: 22/03/2009 14:02    Sujet du message: Répondre en citant
Beautiful sailplane , good job , congratulations..!
Cem
Nouveau messagePosté le: 22/03/2009 14:24    Sujet du message: Répondre en citant
[clap] [clap] [clap] Congratulations, it's realy splendid, have a lot of good fly whith it.
Miguel Gil
Âge: 70 Taureau
Nouveau messagePosté le: 23/03/2009 00:46    Sujet du message: Répondre en citant
[clap] [clap] [clap] [clap]
Congratulations, great post and beautiful sailplane. I hope you have a sensational first flight and shows us the photos,
Un saludo,
Miguel.
cw
Âge: 78 Sagittaire
Nouveau messagePosté le: 24/03/2009 21:02    Sujet du message: Répondre en citant
Merci messieurs... I hope the Steinadler will fly as well as the Minimoa.
Here is the Minimoa in action on the slope last weekend...(For you, Paul Very Happy Very Happy )
http://www.youtube.com/watch?v=xNpQKHAG_bQ
cw
Âge: 61 Gémeau
Nouveau messagePosté le: 24/03/2009 22:36    Sujet du message: Répondre en citant
Hallo Chris Very Happy ,
i can say only your Steinadler OE 0415 is so perfect [amen] [clap] [clap] .
Congratulations Chris
Greetings
Paul ELLIS
Âge: 79 Verseau
Nouveau messagePosté le: 25/03/2009 00:28    Sujet du message: Répondre en citant
Absolutely outstanding Chris [amen]
The music on the vid is very moving, what is it?
Chris Ze Swiss
Âge: 60 Taureau
Nouveau messagePosté le: 25/03/2009 01:02    Sujet du message: Répondre en citant
[bave2] [baaave] [bave2]
All I can fell !
Simply GREAT !
Thanks, Christian
Page 3 sur 5
